Leaking Diff?
Old Jun 3, 2004 | 10:02 PM
FormulaTwo's Avatar
Unhappy Leaking Diff?
Got down and dirty and removed my broken front right CV axle today. When i removed it from the DIfferential there was alot of fluid that came out unexpectedly. I am not sure if this is normal. Anyone know?
It says that it takes 75w90 on the diff itself, but damn i didnt expect i would have to change the fluid when changin the axle???
The only thing i can think is that i might have broken a seal inside of there somewhere???? Any ideas on this?
Also would it be safe to fix the seal later on down the road and still drive it as long as i dont go into 4wd?
Not really sure how the ADD works on there.
thanks in advance.
Sam
Old Jun 3, 2004 | 10:10 PM
superjoe83's Avatar
its normal for oil to come out, it was just full which is a good thing as long as there is not oil leaking out of the diff the seal is fine
Old Jun 3, 2004 | 11:25 PM
FormulaTwo's Avatar
should i buy new oil to refill what came out? I dont plan on driving in 4wd for a couple weeks. Going on vacation, just need the truck to get around.
Old Jun 3, 2004 | 11:30 PM
superjoe83's Avatar
i would, its not too hard, just take out the fill plug and fill it until its level with the fill hole, even though you wont be in 4wd for awhile, because you have ADD the axles and pinion (spider) gears will be spinning and will need lube, you probably have enough in it right now, but i would play it safe and fill it up
polo451
13
Nov 20, 2016 07:49 PM
jaretstuff
Aug 4, 2015 02:08 PM
yourrealdad
Jul 29, 2015 11:08 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
