Old Apr 15, 2016, 09:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Engine Guides
Print Wikipost
serpentine belt
Old Jun 8, 2004 | 07:39 AM
lee's Avatar
lee
serpentine belt
i did a search, and dint find anyone with this question...
my serpentine belt is squealing when i first start the engine, doesn't always happen, but when it does its pretty annoying. it goes away after about 10 minutes of run time.
should i replace it or can it just stay on there for a while longer? i dont see any tears in it, and it doesnt appear to be all that worn out. isn't there a fluid i can spray on there to make it stop?
thanks
Old Jun 8, 2004 | 12:02 PM
SLC Punk's Avatar
Sounds like it may be lose. Check the tension on the belt, it may just need to be adjusted.
The anti-squeak stuff is temporary, usually only lasts 1-2 days.
Old Jun 8, 2004 | 12:04 PM
lee's Avatar
lee
i checked it and its not loose.. that was my first instinct as well.
what is the anti-squeak fluid called?
Old Jun 8, 2004 | 12:27 PM
dcampen's Avatar
I had a car once that did this sometimes, a Dodge sedan. I tried tightening the belt but still it would start doing it again. I don't think it hurt the belt since it would stop after a short while.
Old Jun 8, 2004 | 12:36 PM
bike4miles's Avatar
Yea, try some belt dresing. It sofens the rubber and makse it stick better.
Old Jun 9, 2004 | 04:04 PM
4Legz's Avatar
first off, its not a serp belt, its a v-belt =) morning sqeaks happen all the time, usually the belt has stretched or the surface is glazed. Spray with silicone spray, belt dressing, etc on one part of the belt while the engine is running. If the sqeaks stops, you need a new belt. If not, its a tensioner issue or another belt. Hit them all with the spray, just dont use too much. For what its worth, i have never seen a 3.4 with a bad tensioner.
MJ
Old Jun 9, 2004 | 06:14 PM
lunatic14r's Avatar
check the groves in the pulleys for junk if the belt is old or was loose at one time you may have rubber build up in the grove causing your problem
Old Jun 9, 2004 | 06:54 PM
lee's Avatar
lee
guess that means i need a new belt. sound went right away.
Old Jun 9, 2004 | 07:07 PM
Strider's Avatar
Mine does the exact same thing after it rains. I have had it tightened..didn't work and the lube is only temp. I am still under warranty so maybe the stealer will replace it.
primordialbeast117
Dec 19, 2015 12:23 PM
mbomberz1
Oct 9, 2015 07:17 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
