check engine light and speedo quit
Old Jun 15, 2004 | 03:30 PM
Paul H.'s Avatar
While driving today, my check engine light came on and at the same time the speedometer quit working. Truck seemed to rum fine for the short time I drove it. Any guesses? Thanks.
Old Jun 15, 2004 | 03:37 PM
PoBoy's Avatar
Does the odometer still work?
Old Jun 15, 2004 | 04:04 PM
Paul H.'s Avatar
Did not notice, to tell the truth.
Old Jun 16, 2004 | 12:17 PM
Fahrenheit 451's Avatar
A possibility:
http://autos.msn.com/research/vip/Re...1&src=vip#Tran
Hopefully, it is something easier and cheaper.
Old Jun 16, 2004 | 12:24 PM
Paul H.'s Avatar
Thanks Fahrenheit, do you or anyone know how to check the speed sensor or where it is located?
Old Jun 18, 2004 | 03:21 PM
Paul H.'s Avatar
Update: check engine light went out but my speedo and odometer do not work. Could it still be the speed sensor or something else? Anyone.
Old Jun 18, 2004 | 08:45 PM
DavidA's Avatar
Check your fuses...some supporting circuit could be down. Just a thought.
Old Jun 19, 2004 | 05:17 AM
HondaTec521's Avatar
I just bought my '90 runner and i could have sworn it has a cable driven speedo. Maybe your cable broke/disconnected ? You probably have a speed sensor code.Or a transmission code.
Old Jun 19, 2004 | 01:05 PM
Paul H.'s Avatar
All fuses checked good.
Hondatech, where is the speedo cable and is there a way to check to see if it is bad?
Old Jun 19, 2004 | 08:37 PM
UKMyers's Avatar
My 94 is electronic but if you have a cable it's behind the cluster.
Old Jun 25, 2004 | 11:25 AM
Paul H.'s Avatar
Update: Decided to take 4Runner in and have it checked out by a mechanic. Turns out that a sensor attached to the transmission went out. The cost of this part: $317.00 Only Toyota sells this part. No one else does.
Old Jun 25, 2004 | 07:26 PM
Woof! For that much, see if you can find a junkyard version or somebody on the board parting out a 4runner. Seems like there are a couple in the classifieds lately.
Also, a bit of a reach, but have you considered taking the sensor somewhere to see if it can be repaired like an electronic supply/repair house? I wouldn't be the least bit surprised to find out there is a $0.10 resistor or something similar that burns up and could be easily replaced. Heck, there could even be something that gets a bit corroded/dirty that requires pulling the sensor apart to repair. I doubt there is a core charge so what is there to lose by messing around with the dead one.
I'm not electronics whiz kid, but I have fixed a couple relays/switches on my 4Runner in the past that I bet the dealership would have told me could only be replaced at mucho $$$.
Just a thought.
Don't necessarily believe them when they say it is a dealer only part too. It takes some hunting, but I have found parts clearinghouses in the past on the net that deal in old dealer inventory on parts that aren't high volume enough for the dealers to care about and have found the prices to be lower. I don't remember the site(s), but hey for what might be a couple hundred $$ savings you can afford to surf the net for a while
Old Jul 2, 2004 | 03:15 PM
Paul H.'s Avatar
newer update: Well they replaced the sensor and guess what, it did not fix the problem. They did some more troubleshooting and after scratching their heads for awhile, they decided that they had no clue what was wrong. They said take it to toyota. Good news, they did not charge me for the part or the troubleshooting time. While driving to toyota the check engine light came on again. They now have it, I called them at 4:oo today and they told me they were checking it out and would call me before they closed if they found anything. No call back today. I just hope that it will not be very expensive. I miss driving my 4Runner and want it back.
Old Jul 2, 2004 | 04:09 PM
M3TA4's Avatar
paul,
I just had my secondary speed sensor replaced, it is located behind the instrument cluster, apparently the primary is on the tranny. My 4runner was doing the same thing only it would not shift out of 1st unless I manually did it, its automatic. It was intermittent so I knew it wasnt mechanical, the local Toyota dealer in Hattiesburg, MS tried to tell me I needed a new transmission, AAMCO hooked the computer up to it and told me about the sensor took em a coupla days to get the part from Toyota.
Old Jul 2, 2004 | 05:43 PM
Paul H.'s Avatar
M3TA4, the primary is the one the mech. replaced. Must be the secondary. I wish I had gotten your message earlier. Oh well, hopefully they won't try to screw me over.
Old Jul 20, 2004 | 04:09 PM
SD70MAC's Avatar
I'm experiencing a similar problem on my 89 4runner. I was driving on the interstate and all of a sudden the speedo needle just dropped to zero and the odometer quit working. When that happened, the CEL came on and the "OD OFF" light flashed. I took the cluster out and the very end of the speedo cable had broken off. I went to Toyota and they sold me a new cable which took me 3 hours to put in. The connector to the back of the cluster appeared a little bit too big, but I decided to try it anyway. It wasn't but about 10 minutes later when I went for a test drive that the NEW cable broke too in the exact same place! I just got home from the dealer and he ran the vin # and found out the cable he sold me originally was the wrong one. If you have to replace the cable, make sure you give them your VIN # so they can get you the right cable!
Old Jul 20, 2004 | 10:08 PM
Sludge's Avatar
Im having the same problem on my 92 Runner. Needle drops and the CEL comes on. Any updated info on this would be greatly appreciated.
Old Jul 21, 2004 | 03:14 PM
Paul H.'s Avatar
Update: it was the actual speedometer, not the cable. Dealer replaced it. Cost almost $400.
Old Jul 21, 2004 | 03:57 PM
Robinhood150's Avatar
Hmm...didn't see this post back in June.
Do a search for vehicle speed sensor and my name. Not sure which year they switched from cable to electronic though.
sonic concepts
Aug 16, 2025 03:13 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
