Torsion bar problems...
Old Jun 10, 2004 | 05:06 PM
WSU4runner's Avatar
Ok, I just completed my lift and am running into some problems adjusting the height. Ground to fender on the driver side is 40" and 39" on the passenger side. Problem is the passenger side won't get any higher, it's as high as it'll go. Besides lowering the other side are there any solutions??? I like the looks of the driver side better, it matches the rear almost exactly. Thanks for the help guys.
Old Jun 10, 2004 | 05:21 PM
sportJr's Avatar
Go top of the rim to fender, Make it easier to tell where you are at with your height. Might be maxed out, might be hung on adjuster nut. They do get stuck, take it from someone who had to break both bolts to get them apart. Well both bolts and a 22m wrench that had a lifetime warrenty. That hurts, fyi
Old Jun 10, 2004 | 05:26 PM
Victor's Avatar
The nut often seizes on the adjusting bolt. You can get both at a Toyota dealer.
Old Jun 10, 2004 | 06:16 PM
WSU4runner's Avatar
Ok, thanks.
But the bolt that you twist to adjust height looks like it's at it's max. It's just going into the rubber piece. There's not a lot of thread left either. It seems that both bolts are different lengths. Should I just get 2 new bolts and nuts? (haha, just sounds kinda funny)
Old Jun 10, 2004 | 06:25 PM
mt_goat's Avatar
Originally Posted by WSU4runner
Ok, thanks.
What rubber piece? Mine doesn't have any rubber piece. What happens when you turn the adjustment bolt? You are jacking the front end off the ground before adjusting right? See if this helps any http://www.off-road.com/toyota/tech/torsion/index.htm
Old Jun 10, 2004 | 06:47 PM
KevyWevy's Avatar
hey guys, could it be his shocks if they're hyper extended, then they wont let the control arms drop any more right?
Old Jun 10, 2004 | 07:26 PM
BeaterToyota's Avatar
Could have something to do with the shocks.
Could also have something to do with the gas tank being on the passenger side. My truck has never sat level. The passenger side is always lower, and even more noticeable when the tank is full.
Old Jun 10, 2004 | 09:05 PM
WSU4runner's Avatar
Hey Kevin, how did your truck end up? are all the measurements equal (front and rear)? Or is your rear higher?
Old Jun 10, 2004 | 09:27 PM
KevyWevy's Avatar
front and back are the same, but side to side is 1/2" off cause i used one long and one short coil
Old Jun 10, 2004 | 09:33 PM
WSU4runner's Avatar
Why is my truck so different??? Grrr...
Maybe you can take a look at mine this weekend. I can get you the stands as well.
Old Jun 10, 2004 | 09:34 PM
KevyWevy's Avatar
yeah, whatcha doin tomorrow?
Old Jun 11, 2004 | 04:23 AM
mt_goat's Avatar
Good point, 16 gals of fuel weights about 130 lbs. Throw some weight on the other side to balance it out, or have your mother-in-law sit on the drivers side.
ladybugRC
458
Aug 21, 2020 10:41 AM
choppe777
May 16, 2016 08:00 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
HiLuxer
Sep 9, 2015 02:43 PM
