Speedometer Cable Removal
Old Jun 12, 2004 | 02:18 PM
corvettelvr73's Avatar
Question Speedometer Cable Removal
How do you take the speedometer cable out? I think I need to grease mine because it bounces slightly.
Old Jun 12, 2004 | 03:07 PM
Bump !
Old Jun 12, 2004 | 08:20 PM
Flamedx4's Avatar
The end at the trans or transfer case just unscrews. The end at the speedo can either unscrew, twist lock, or have a funky clip. When you see it there will be no question. The cable can simply be pulled out of the casing. Putting it back in, by the way, is damn near impossible. It will teach you patience and reward perseverance.... Get a six pack and breath deeply...
Old Jun 13, 2004 | 05:24 AM
gwhayduke's Avatar
My speedo does the same thing...probably from being lubed by a leaking output shaft seal on the transfer case and then getting dusty on dirt roads. The dealer told me I needed a new speedo cable...$75 if I remember right. It's still sitting on the shelf waiting for me to feel real ambitious.
I don't think they're supposed to be oiled...maybe a dry lube?
Old Jun 13, 2004 | 06:33 AM
I ordered my speedo from TOR on this forum. It was $60 shipped. THe install on my 89 wasn't overly difficult, took about an hour.
Old Jun 13, 2004 | 01:27 PM
abalagtas's Avatar
I thought after '92 they were all electrical speedos. Mines a '91 and has a cable my buddies is a 93 and his was electrical....just a thought before you go spending $75.
Old Jun 13, 2004 | 06:03 PM
ChickenLover's Avatar
My 95 has a cable. I've had it replaced once and the damn thing is on it's way out again (not even a year later).
Old Jun 15, 2011 | 11:59 PM
arc_shuxson's Avatar
Removing cable from behind Combination meter
I came across this post on removing speedometer cables and had the following questions. I have a 95 4runner and was considering greasing the speedo cable. I took apart the dash and removed the instrument panel box or combination meter box to expose the speedometer cable. It sounds like from the posts on here that it is possible to remove the cable from this location is that true and how? What about feeding it back in from here? I pulled up the floor matt to see where the cable went through the body frame and located it on the underside of the car. I tried following it around but loose it above the transmission and cannot see nor feel where it is going or how I would even access it to remove it from this location. Any help would be greatly appreciated.
Old Jan 28, 2013 | 01:12 PM
TURBOrunnerNM's Avatar
I'm guessing your rig is 4WD? If it is then you can unscrew the cable for the rear of the t case. It's located on the passenger side of the rear output shaft. There's a retainer clip held in place by a 12mm bolt. Pop that out to make sure the driven gear isn't damaged. Wear eye protection as some fluid will drizzle out. If the gear is ok then put it back together and unscrew the cable itself. There are a few tabs along the body you'll need to undo to get the cable free. Good luck
Old Aug 26, 2014 | 07:42 PM
ChzSoda's Avatar
How does one get the cable actually loose from the truck? I am at the final step, where it goes through the same metal piece as the E-brake cable. It's detached at both ends, just the seemingly impossible metal piece where it goes through the floor.
Help?
okamikai
Apr 30, 2018 10:19 PM
mund1011
Aug 16, 2015 07:10 AM
teknovls
Aug 9, 2015 12:37 AM
altydog
Jul 28, 2015 10:20 AM
wilbertd
Jul 6, 2015 07:39 AM
