keyless beep
Old Jun 13, 2004 | 09:46 PM
MellamoPOUND's Avatar
keyless beep
hey, I tried searching but didnt get very good results ... soooo... I am wondering if there is anyway I can get my 1997 limited 4runner to beep when I lock it with the keyless remote. Right now, all it does is flash the lights and its hard to tell during the day if it locks or not when I am walking away from it. Gracias!
Old Jun 13, 2004 | 10:13 PM
keisur's Avatar
My alarm manual that came with the 4runner has the sequence of turning the key in the ignition with engine not running (all dash lights on) and pressing in and out the valet switch 3 times and then turning the ignition off again. then it will beep. to turn off the beep, I do the sequence again. check your alarm manual if you have it.
Old Jun 13, 2004 | 10:34 PM
Bob_98SR5's Avatar
mellamo,
assuming you have an rs3000, go to my page here at http://www.4runners.org/articles/rs3000
download the user's manual and you shall find your answer, young grasshoppa.
bob
Old Jun 13, 2004 | 10:56 PM
BajaRunner's Avatar
Yeah, I did the same thing, but, I turned the "chirp" off. I cant handle that crap.
Old Jun 14, 2004 | 07:50 AM
keisur's Avatar
same here, but mine beeps the horn lightly. since I got the freeway blasters it would be pretty annoying. I wonder why I don't have the RS3000.
Old Jun 14, 2004 | 07:52 AM
SLC Punk's Avatar
Yep the beep is pretty annoying. Mine only works 1/2 of the time and I can't figure out whats wrong with the little churper.
Old Jun 14, 2004 | 07:56 AM
keisur's Avatar
sometimes the button on my key gets stuck and wears the battery down, then I gotta go throught the key turn/valet switch sequence to disarm the "starter disabled" mode just to start the thing after manually opening it with the key. in a crowded parking lot or outside a restaurant window or even in your own driveway, everybody stares.
Old Jun 14, 2004 | 07:59 AM
I dont think I have the RS3000 alarm but I'll try programming the keyless entry again. Thanks guys.
Old Jun 14, 2004 | 08:20 AM
keisur's Avatar
can you snap a pic of the valet button and the black box under the drivers dash? I think you might have the same one I have. if so I can give you detailed instructions because I have the manual for it. look in this pic, if your button look like mine ( the round red button by the dimmer switch) then you probably have the same one I do. let me know.
Old Jun 14, 2004 | 10:14 AM
BajaRunner's Avatar
SLC... Same with mine!! I cant figure that out. I turned it off, but, once in a while it will beep anyways...
Old Jun 14, 2004 | 10:22 AM
Bob_98SR5's Avatar
SLC and SC:
i have the same problem. someone at the dealership told me that it is because the battery is weak.
bob
Old Jun 14, 2004 | 10:31 AM
keisur- I went and looked, and I dont have a security light anywhere, so I am guessing I dont have an alarm system. Maybe I can't make mine beep?
Old Jun 14, 2004 | 01:08 PM
Cebby's Avatar
You can wire in a module that will beep into the parking light circuit. (the wire that flashes you lights - isolate it with a diode or it will go off all the time...)
I have one that I'll be using at some point. I'll post a pic of it later. I can't remember who made it or where it came from.
You can probably strip one off of a Lexus at a salvage yard. Not sure what theirs looks like though.
Old Jun 14, 2004 | 02:39 PM
cool... thanks for the idea!
Old Jun 14, 2004 | 04:15 PM
IamaFan's Avatar
what does your remote look like? i don't think 97s had it, but do you have the keyless entry remote w/ a lock,unlock, and open window button? i know on mine the volume of the chirp can be adjustedby using the keyless entry remote. i can hold the unlock button for ~3 seconds and get a double chirp. while still holding the unlock button, pressing lock increases the volume and window down decreases it.
Old Jun 14, 2004 | 05:56 PM
keisur's Avatar
my remote is part of the key. I don't think the separate fobs came out until '99 or so. at least I think. it's got lock, unlock and a green button that will turn the headlights on and if either the lock or the green button is held down it turns into the panic button.
Old Jun 14, 2004 | 10:15 PM
My remote has two buttons like the RS3000. The top locks and unlocks, and the bottom is for programming into another toyota.
Old Jun 15, 2004 | 02:02 AM
Mossback74's Avatar
Mine does the same thing,
Old Jun 15, 2004 | 02:58 AM
Cebby's Avatar
Old Jul 24, 2004 | 06:12 PM
4-RUNNIN' FREAK's Avatar
This does not work on my '02. I tried many button combos, and nothing happens.
