Help...3vze runners,where does this wire go
Old Jun 10, 2004 | 01:55 PM
Maddog's Avatar
Im just in the middle of changing my plugs,& have found this wire that looks like it should be earthed.Im sorry i dont have a pic,but if one of you look at the base of your ignition coil,there is a little black plug with numbers on mounted on the sercuring bolt.it has two wires coming from it ,one leads into a buch of wires in a black tape/plastic surround,the other goes into a male/female type conection then out of that conection is a thick taped up wire with a large flat washer style fitting on the end(this is the bit that is roaming free),I need two know where this washer type fitting is ment to be mounted (presuming its a earth)either on the engine block or the chassis.
can someone point me in the right direction.
Old Jun 10, 2004 | 02:20 PM
Maddog's Avatar
anyone....im just taking a rest from the dredded Number 6 plug,it would be easy if i had a bendable extention.
Old Jun 10, 2004 | 02:39 PM
eric-the-red's Avatar
Because I'm such a nice guy, (and work is really boring today) I just had a look at mine. The wire is definitely a ground. The end near that little plastic block grounds to the inner fender about 10 cm away from the coil. The other end attaches to the driver side valve cover, or I guess passenger side in your part of the world.
Old Jun 10, 2004 | 02:50 PM
Maddog's Avatar
Many Many thanks Eric the Braveheart .I had a suspicion thats were it went,but need to know for sure.
cheers Mate
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
OffroadRalph
Jul 2, 2015 07:28 PM
greenbuggy
Jun 28, 2015 10:40 AM
TheManOutside
Jun 18, 2015 03:32 PM
