Trail Master Helper Springs...???
Old Jun 14, 2004 | 01:54 PM
brendonv's Avatar
My friend gave me a set of brand new rear Trail Master Helper springs. I have a 1987 Pickup and was wondering if they would fit it. The helper springs do not have any vehicle application names on the box. I do know that the new spring bolts on top of the old ones with a bolt going through the sprrings. Do the stock toyota springs have a hole in the middle of them??? If they do then i could use these helper springs. Any help appreciated.
BrendonV
Old Jun 14, 2004 | 04:06 PM
elripster's Avatar
BrendonV
Every leaf spring pack I have ever encountered has that hole in the middle with a bolt going through it. It both locates the spring and keeps the leaves aligned.
Have you measured how wide your helper spring is compared to the Toy springs? They'd need to fit between the Ubolts.
That cap screw that goes through the springs might not be long enough with the helpers, you might need to be able to break away from the job for a run to a hardware store. I'd make sure you have another way to get there while the truck is apart.
Otherwise, there is no way to know if this will work or give you the results you want, you'll just have to try it and see if you like it.
Frank
Scatterbrain
Sep 27, 2015 08:24 AM
mxdw88
Sep 20, 2015 03:13 AM
sonorn67
Sep 19, 2015 05:39 PM
old87yota
Sep 9, 2015 12:39 PM
Squigglez
Sep 4, 2015 07:33 AM
