Need some horn help.
Old Jun 8, 2004 | 07:04 PM
FSRBIKER's Avatar
Heading for inspection with the 85 4Runner in the morning but my horn sounds REAL low. If I directly connect it to the battery it's loud so somewhere i have a bad connection?? or maybe a relay is bad??
Thanks in advance.
Old Jun 8, 2004 | 07:08 PM
jimbo74's Avatar
check the wiring... jiggle fises... check the grounding of tis location...
Old Jun 8, 2004 | 07:14 PM
FSRBIKER's Avatar
I unplugged/removed the horn and did a quick clean of the plug... then cleaned up the horns terminals and ground/bolt. Also cleaned the fuse on the passenger side fenderwell. Still no louder.
Old Jun 9, 2004 | 05:20 AM
HondaTec521's Avatar
Try cleaning the slip ring on your steering coloum.But you have to pull the steering wheel to do it.
Old Jun 9, 2004 | 01:17 PM
FSRBIKER's Avatar
Well I failed inspection for the horn today and a tinted drivers window...so I'll look into the slip ring as well as trace all the wiring.
zytra
Jan 24, 2019 03:16 PM
Shagool22
Sep 28, 2015 07:53 PM
fountain
Sep 28, 2015 03:04 AM
LotOMiles
Sep 14, 2015 11:45 PM
xzen73x
Sep 14, 2015 03:00 AM
