TRD brake rotors for 3rd gen Pickup? Need them ASAP!
Old Jun 8, 2004 | 08:24 PM
Juggalo's Avatar
Hey guys, my brake pads and rotors are getting pretty worn, and I was wondering if Toyota makes TRD rotors and/or brake pads for my Pickup.
If I'm going to get new brakes that will stay on for a while, then I might as well get the best.
If TRD parts aren't available, then do you guys reccomend any other rotors/pads besides Toyota factory ones?
PS: Where can I find steel brake lines as well? And do drum brakes need to be replaced often?
Thanks
Old Jun 8, 2004 | 08:44 PM
humanoid's Avatar
Yota rotors tend to warp over time. Many have used Brembos and swear by them. OEM brake pads are good for those rotors, but tend to create a lot of dust. Not sure what pads others use. The drums won't need to replace as often as the pads, but it's good to take a look at them to check out their condition.
Old Jun 8, 2004 | 10:05 PM
DavidA's Avatar
If I had the money I would go with the Brembo Rotors and Ceramic Pads.
Just my 2 cents.
Old Jun 9, 2004 | 12:17 AM
Juggalo's Avatar
Just my 2 cents.
Thanks man
My MX-6 had Brembo rotors with EBC green stuff pads, and steel brake lines. Needless to say, it stopped on a dime, and saved my ass several times at high speeds. (cost $1,000 just for parts)
Anybody have a link to where I can get Brembo rotors, good ceramic brake pads, and steel brake lines?
Thanks
Old Jun 9, 2004 | 05:26 AM
SLC Punk's Avatar
I heard a while back that the TRD pads were made by performance friction. I ended up getting the performance friction pads from Autozone and just turned my rotors. I did that last year and can already feel a slight warpage in my rotors.
I may have to go with Brembo rotors next time.
Old Jun 9, 2004 | 06:45 AM
Bennito's Avatar
Originally Posted by Juggalo
Thanks man
Thanks
Go look and see if you have banjo nuts or flare nuts. Then check out AOR (clicky). I recommend calling to make sure you get it right. Plus you can specify how much lift (if any) you want.
Old Jun 9, 2004 | 06:50 AM
calg3's Avatar
www.tirerack.com has all those parts you want for your 4Runner
I ordered cermaic brake pads for our Subaru from them and the Brembo rotors for my 4Runner from them. Great customer service.
Old Jun 9, 2004 | 08:19 AM
Juggalo's Avatar
Thanks man, I appreciate it
Now come the decisions, do I go with the normal Brembo rotors (plain vented) or do I get the dimpled and slotted Powerslot?
Any suggestions?
Old Jun 10, 2004 | 06:02 AM
calg3's Avatar
Any suggestions?
I can tell you from my personal experience, it is up to you what you decide to do. Since my truck came with the 15" wheels, I have the smaller front rotors. I was trying to improve the braking situation so I went with the TRD carbon brake pads that I got on special. Those work great. I also bought a set of the dimpled drilled rotors, not Power Slots, a set from JC Whitney. They warped in the first month I had them. They only had a two week warranty. They cannot be turned and are side specific. So now I am using a set of Wearever rotors, only $30 each. They are working fine and have a year warranty. The dimpled, drilled rotors did not stop any better for me. I am sticking with standard rotors.
MudnBullets
Oct 28, 2018 07:00 PM
miceal383
Jun 29, 2015 12:27 AM
Iceman4193
Jun 28, 2015 10:30 AM
williemon
Jul 29, 2002 08:17 AM
