hot manual transmission
Old Oct 1, 2016 | 11:11 AM
lotalucas's Avatar
My transmission is getting so hot I feel the heat through floor boards. Any ideas on what can cause this. I'm thinking putting new fluid won't hurt but I can't see old fluid making it heat up that much. The clutch felt like it was slipping a while ago but I replace the slave cylinder and it solved the problem. I think it just wasn't realeasing the clutch all the way. It's a 2000 Tacoma v6 4x4 manual
Old Oct 1, 2016 | 12:13 PM
Marc's Avatar
It does get hot normally. There's lots of hot stuff around it.
Hit it with an IR temp gun and see what the temp is.
Old Oct 1, 2016 | 02:55 PM
wyoming9's Avatar
Now is it getting so hot you are unable to touch the shifter after driving 5 miles
Your sure it is the transmission ??
I get quite a lot of heat from the crossover pipe after a few hours of driving in 90 Degree temperatures
Old Oct 1, 2016 | 04:08 PM
lotalucas's Avatar
Unfortunately I do now have an ir gun.
Old Oct 1, 2016 | 04:15 PM
lotalucas's Avatar
The shifter isn't getting hot. But if I get under and feel the tranny and transfer case the whole thing is as hot as the engine. I did the timing belt recently a d at first I was thinking it must be off and running rich but the floorboards on the driver side are hot and the catalytic converter is on the driver side. It could be coming from the crossover pipe but it does seem like the whole tranny is way hotter than it should be. It happens in the morning when it's about 70 on a 30 mile drive to work.
Old Oct 1, 2016 | 05:45 PM
Marc's Avatar
Ok, can you hold your hand on the transmission when it's hot?
Old Oct 2, 2016 | 03:18 AM
wyoming9's Avatar
What are you using on your hand for the burns Aloe Vera seems to work pretty good.
If you can touch it.
It is not that hot
Old Oct 3, 2016 | 10:07 PM
Keith B.'s Avatar
It should be hot after driving 30 minutes on the freeway with ambient air at 70ºF. It's getting hot engine air that additionally passes the exhaust manifolds and crossover pipe blown on it 100% of the time, and it's generating a small amount of it's own heat from internal friction. And the exhaust pipes and cat are right near it.
Old Oct 4, 2016 | 07:26 AM
mwisham's Avatar
May be a stupid question, but.......... You have checked to make sure it is full of gear oil, right?
Old Oct 4, 2016 | 08:25 AM
ThorInc's Avatar
Changing the gear oil is super easy, getting the right level is super important........also, you can get a cheap OBDII reader and the torque smartphone app and for your year I believe it provides realtime transmission temp readings.
Old Oct 4, 2016 | 02:18 PM
Marc's Avatar
I don't think it gives you readings for manual transmissions. Temp is never really an issue with them.
pstallard
Nov 15, 2020 02:35 PM
damnthemansam
Oct 3, 2016 05:27 PM
joekerr1@gmail.com
Aug 18, 2016 04:57 PM
doc702
Jul 28, 2016 06:06 PM
