4runner 2.7 clutch
Old Sep 16, 2016 | 08:23 AM
L4g63t's Avatar
So as some know not to long ago I worked on the transmission. Well after 1500 miles the clutch went out. I was at a stop sign when I heard tires and saw smoke heading my way from the rear. I pretty much burnt my clutch taking off to avoid getting hit. My truck is in one piece but my clutch is slipping now. I have been looking at Marlin and aisin clutches. I even found oem Toyota clutch/ pressure plate for right under 200 without flywheel and other needed parts. I am slowly building my truck and will be driving out doors once a month or so. What clutch do you guys recommend??
Old Sep 17, 2016 | 12:48 AM
wyoming9's Avatar
If you took out the clutch just dumping it one time it must have been at the point of failure !!
Go with either the Aisin or Marlin Crawler although if your hard on clutches the Marlin is the way to go
Old Sep 17, 2016 | 02:10 AM
Toyauts's Avatar
oem
just get the poem clutch and replace it in 1500
Old Sep 17, 2016 | 06:33 AM
L4g63t's Avatar
The Marlin does seem like a better option. I went on Toyota parts everything clutch, rear main seal, fork, bearings, clips, etc comes out to be $330 that's extremely cheap for being all oem from Toyota.
Old Sep 18, 2016 | 01:32 AM
wyoming9's Avatar
Did you price out the clutch plate
the clutch release bearing
The pilot shaft bearing as well
It is not like Toyota has a clutch kit each item needs to be priced separate .
Then just how does the fly wheel look
Old Sep 18, 2016 | 06:46 AM
L4g63t's Avatar
Yes everything you order is separate. All that included and rear main seal. Flywheel is unknown as I have yet to take out the transmission again. Oem flywheel is expensive so I might just buy one off Marlin they sell used ones resurfaced already.
Old Sep 18, 2016 | 07:02 AM
ThorInc's Avatar
Marlin Crawler 1200lb clutch kit (tell them to check box for all right parts, wink) & a TOYOTA REAR MAIN SEAL.
stanz
16
Feb 5, 2025 01:09 PM
BigMike
May 30, 2019 08:28 AM
ShadowTek
Oct 10, 2016 05:53 AM
Poppie51
9
Jul 25, 2016 08:39 PM
drWhite1965
Jul 9, 2016 06:32 PM
