98 4runner no power help ?!
Old Aug 27, 2016 | 11:04 PM
hotrod758's Avatar
I have a 98 4 runner with. 3.4 engine and automatic trans and it's the limited now when I try to use any power whether it's going up hill going from a stop sign it has no power I can eventually get it up to speed I've changed coils and wires and plugs I also gutted the cat out changed fuel filter and I p300 p302 for cylinder 2 and 5 but I have no misfire in engine do you guys have any advice ? I did change the mass air flow but not with a new one a changed with a used one thanks for any help in advance
Old Aug 28, 2016 | 09:36 AM
Charchee's Avatar
Are those codes for cylinder missfire but you're saying you just can't feel / hear a miss? How many miles on the engine?
Old Aug 28, 2016 | 09:43 AM
hotrod758's Avatar
Yes the codes are for random misfire and misfire on cylinder two and cylinder five, the car has 322000 miles but you cannot feel no misfire
Old Aug 28, 2016 | 10:34 AM
Charchee's Avatar
The reason I asked that is because, when I first started on my old project truck that I bought for $300 because I was told the engine was shot, it had the same kind of issue. After a little work it would crank right up and idle just fine but maybe a little slow. It sounded good and responded well out of gear, but when you went to drive it, it felt like it had maybe 50hp and would not pull a hill whatsoever. After doing a bunch of difficult tests, I tried a simple one. I cranked it up and started pulling my plug wires off one at a time. This one was a 3.0L by the way. I noticed no drop in RPM when I pulled off three of the plugs which let me know I had three dead cylinders. I bought me some aftermarket injectors which were $150 for a whole set and installed them. She's been running great ever since. I'm not saying you have bad injectors but with that many miles, it's sure possible. All I'm saying is that you can't always feel a miss in these engines like you can in a big diesel like I was used to working on.
One more thing, if you're not into troubleshooting engines. Go ahead and change your fuel filter and rule that out. It's a maintenance item anyway and it's cheap and easy to replace. That's always my first step in troubleshooting low power issues. You might also look at your air filter as well and change it if necessary.
Best of luck.
Old Aug 28, 2016 | 10:44 AM
hotrod758's Avatar
I'm gonna test the injectors thank-you I'll let you all know if that works and I have changed the fuel filter and air filter and Dame thing but what you just described is my car to a t acts like it has no power so thanks for the advice on gonna give that a shot
Old Aug 28, 2016 | 10:47 AM
Charchee's Avatar
I've always loved these engines but the fact that mine could drive across country and back (very slowly) on three cylinders makes me love them even more. You'll get it figured out. Let me know if I can help.
Old Aug 28, 2016 | 10:49 AM
fierohink's Avatar
Your injectors will test fine but they are bad. They fail once they get hot. There was a string of guys on here, probably a dozen or more myself included, that had injectors fail this Summer.
Old Aug 28, 2016 | 11:01 AM
Charchee's Avatar
If you go ahead and change out those injectors, you absolutely need to change them all. With that many miles and the time you are going to spend getting down to them, it will be well worth it. Who's to say #4 won't fail the day after you get it all back together. Buy a set.
Joey22r
Feb 27, 2016 04:24 PM
Rosco1977
Feb 6, 2016 06:02 PM
BlackStone
Feb 6, 2016 09:21 AM
westonian18
Feb 4, 2016 01:17 PM
westonian18
Feb 4, 2016 04:56 AM
