Charcoal Canister Replacement Causes Issues
Old Sep 13, 2016 | 04:53 AM
4Runner777's Avatar
Hello ....... I have an 02 4Runner with 260K miles and was running great - solid no problems. Popped an P0446 code for the EVAP system, brought it to the dealer, had the system smoked and found a rusted charcoal filter canister needed replacement. I also had the serpentine belt replaced. When I received the car back, there was an intermittent ticking noise coming from the engine which begins after the engine is warmed up then it is sporadic - really annoying. Also, my instrument cluster lights are completely dark. The tail lights, Tail Breaker under the hood all check good. But I did see that the towing lights wire dangling in the rear with the cover off. My thought is perhaps the Toyota mechanics damaged this wire in some say during the canister install in the rear that shorted out my instrument cluster lights. The gear lights (P, N, D, etc) all work as well as the annunciation lights too. Also, I believe there is an EVAP valve between the firewall and engine - could this be the cause of the ticking problem. Since the ticking sound is sporadic, the valves are probably not the culprit. Any advice and wisdom welcomed please. Thanks!
Old Sep 13, 2016 | 12:04 PM
Marc's Avatar
Is the instrument light brightness know turned down?
It can be found on the panel to the left of the steering wheel.
Old Sep 13, 2016 | 12:11 PM
4Runner777's Avatar
Forgot to mention that. No, the resostat has no effect on the lights. The lights remain off regardless of the resostat position.
Old Sep 14, 2016 | 03:05 AM
Buckaroo5's Avatar
The ticking noise could indeed be the EVAP purge valve - it would cycle periodically and might seem sporadic.
Buckaroo
Old Sep 15, 2016 | 04:46 AM
aowRS's Avatar
The charcoal canister is plastic.
Our trucks do not have a serpentine belt.
Andreas
jtinco
Aug 11, 2016 08:27 PM
My'lil'truck
Jul 14, 2016 11:02 AM
lalojamesliz
Jul 1, 2016 06:51 AM
jtinco
Jun 22, 2016 01:25 PM
danthemanx07
Jun 22, 2016 05:46 AM
