Thoughts on Lifting 1985 4runner
Old Jun 20, 2016 | 08:05 AM
danthemanx07's Avatar
Thoughts on Lifting 1985 4runner - 3 or 4 inches?
I picked up a 1985 4Runner recently. The PO put some very nice 33" Boggers on the runner but he never lifted - or re-geared. As you can imagine it runs horribly and topped out at 50.
I already dropped 4.88 gears in the rear and am waiting on a set for the front. That should fix the gearing issue which leaves me with the lifting.
I had originally planned to build bastard leaf packs using the stock packs and some leaves from some donor packs. My plan hit a snag when I pulled out the driver side rear and found it to be damaged. Thus I at least need to replace one spring entirely. Thus I am looking at either looking for some used springs and continuing with my plan or buying new lift springs all the way around.
I guess I am trying to determine which way to go at this point. At the very least I figure I am going to have to replace all the bushings on any stock leafs I pickup. Between that cost and the cost of a set of at least a pair of used rear springs, I am going to be getting into the neighborhood of the cost of new springs.
Anyone have an opinion on which would be the more prudent route? I am
Leaning towards all new springs at this point. Just looking for the opinion of someone that has been in a similar spot.
Lastly, is there any substantial difference in effect on the steering or any other issues between lifting 3 or 4 inches? The springs I am considering come in 3 and 4 inch varieties. Currently running 33x10.50x15s on stock wheels. May add some wheel spacers - 1.25 or 1.5 inch.
Thanks.
Old Jun 20, 2016 | 09:08 AM
bccooper's Avatar
My plan is to just buy the rough country 3" complete lift with shocks for 285$, I am in need of new front springs and all shocks so I found this to be my best bet. plus it should work with your 33s
Old Jun 22, 2016 | 05:46 AM
Thanks for the thought. I did look at that. It won't work for me though with a busted rear spring - unless I buy some used stock ones. At that point, I would again be nearing the price of four new springs.
I think I am going to just go ahead and scoop up four new Procomp 3" or 4" springs. They seem to get mixed reviews on here and other yota sites - if not slightly more negative as a result of stiffness. I'll figure out the shocks later - probably use what 4crawler did for his initial lift or something similar.
Ideally, I would like to do Chevy's in the rear and new springs or rear springs up front, but I just don't have the budget for the fab work in addition to the parts right now. I'd also like to get the 4runner back on the road asap.
Dexter350k
May 19, 2021 10:31 AM
SilentBounty
Mar 22, 2016 10:29 AM
Redrunner3g
Jan 30, 2016 10:15 AM
nrgetic99
Jul 30, 2002 04:57 PM
Bighead
Jul 27, 2002 02:39 PM
