valve adjustment
Old Mar 9, 2006 | 11:26 AM
yotarunner96's Avatar
valve adjustment
when do you know that its time for a valve adjustment, and how much does it cost when it is time to do this task?
Old Mar 9, 2006 | 01:36 PM
ricky's Avatar
I would say when you can hear your valves clicking when the engine is warm. From what I've read it's more difficult to do on the newer engines than it was on the 22R. Well, I should say more complicated.
alotawatts's Avatar
I plan on it when I get to about 60k miles. My owners manual / service schedule probably indicates first valve service at 100k miles...like the spark plugs. No way am I waiting that long.
Did my plugs at 35k.
Old Mar 9, 2006 | 01:41 PM
boraxman's Avatar
I dont think they can be adjusted on the 3.4, but "shimmed" if need be. A major pain from what I understand.
Old Mar 9, 2006 | 01:42 PM
ricky's Avatar
I've never had mine adjusted, I've got 192k. They're just starting to make some noise, so I think it's time.
Old Mar 9, 2006 | 04:05 PM
ever since i had my timing belt changed it has seemed to make a wierd noise at idle, i dont know if is something to do with timing, or valves, or if for some reason the engine idle sound is a little bit different after the belt is changed. has anyone else noticed or expirenced this?
Old Mar 9, 2006 | 06:21 PM
MTL_4runner's Avatar
You don't really need to adjust (shim) the valves on a 3.4L except in extreme cases.
Did you change the belt or did someone else? ....wonder if it might be a tooth off.
Old Mar 9, 2006 | 07:22 PM
i took it to the stealership and had them do that with the water pump at the same time
Blamalam
Mar 12, 2022 07:34 AM
Jason Webber
Sep 2, 2015 03:30 AM
DukeOfHazard
Aug 16, 2015 01:48 PM
Dennisx2
Aug 4, 2015 01:26 PM
razorman8669
Jul 12, 2015 12:13 PM
