97 4runner 3.4ltr mpg??
Old Mar 14, 2006 | 10:24 AM
fishin4life0228's Avatar
So I bought this runner about 6mths ago with plans to make it a camping/trail rig I got some money into it and all that good stuff now. Im totally realizing that i get like 12.5 mpg avg.. I do kinda a lot of city drive but still it sounds outragous. I might as well be driving a 77 cadilliac with a big block. Could there be somthing wrong. I do have jardire exhausat and deckplate mod but thats it as in engine. Thanks in advance
Old Mar 14, 2006 | 10:27 AM
FilthyRich's Avatar
bad 02 sensor??
dirty air filter??
bad fuel filter???
dirrty MAF sensor???
incorrect tire pressure???
Old Mar 14, 2006 | 10:29 AM
rimpainter.com's Avatar
Correct calculation?
Old Mar 14, 2006 | 10:37 AM
I changed fuel filter air filter... What am i not worth my calculation haha... 210 miles on a full tank i get.. I will check MAF and 02 today.. thanks for the posts guys!!
Old Mar 14, 2006 | 10:41 AM
Fill up, reset the trip meter. Run it close to E. Divide gallons used by total miles traveled. Repeat 3X (at least), calculate average.
MTL_4runner's Avatar
The calculation should be done:
(mileage @ this fillup - mileage @ last fillup) / (gal of gas @ this fillup)
Repeat for more accuracy.
Old Mar 14, 2006 | 01:32 PM
dragr1's Avatar
Make sure you use the gallons at fill up, b/c a lot of the 4Runner gas gauges are not accurate, such as mine, and will read empty and still have 4-5 gallons in them.
Old Mar 15, 2006 | 06:20 AM
X-AWDriver's Avatar
How amny gallons are you filling up with? Sometimes I only get a little over 210 a tank but I only can squeeze in 15 gallons at fillup so that's more like at least 14mpg.
Old Mar 15, 2006 | 08:23 AM
Gerdo's Avatar
I would bet on a dirty MAF. You are right My low fuel light comes on and I drive 30-40 more miles. I start to get nervious about running out of gas, it only takes 15 -15.5 gals. The tank on a 2000 is 18.4 gals. I get 20 -21 MPG on my 2000 even when pulling a trailer up the mountains I still get 19 mpg. I just did a trip to SLC and back with 4 adults, the back full and a hitch carrier full and got 20 mpg. At 12.5 mpg you have something wrong.
Old Mar 15, 2006 | 08:26 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Be sure you do the calc like MTL_4Runner said, fill-up to fill-up. Forget the PER TANK crap. You want per gallon, and the calculation works whether you put 4 gallons or 14 gallons in...
Old Mar 16, 2006 | 03:25 PM
werdwerd's Avatar
I bought a 97 4runner about 2 months ago and have the same problem.
I need a tune up and hope that will help! it sucks!
Old Mar 16, 2006 | 04:50 PM
cancow's Avatar
I get 16 in the city and I thought that was bad.
Old Mar 17, 2006 | 08:09 AM
X-AWDriver's Avatar
Actually I've been getting over 230 a tank lately (I think tire pressure was low before) and only getting 14 gallons in when I think it's empty so I'm up just over 16mpg which I can deal with.
Old Mar 17, 2006 | 08:30 AM
Tire pressure is a biggy with fuel economy.....about 1 psi lost for every 10 degree drop.
Old Mar 17, 2006 | 11:01 AM
vegaskurt's Avatar
Im getting about 15 to 17 mpg right now. On long freeway trips its closer to 19. I recently did the fuel filter so I hope it goes up a little more (fingers crossed).
When I got the truck the mpg was bad but it improved after running an injector cleaner, changing the plugs, wires and air filter. Cleaning the MAF is next and the O2 is dead last on my list.
Old Mar 17, 2006 | 12:52 PM
surf4runner's Avatar
is there much of a diff between the 3.4L in gen2 vs gen3?
seems like the gen2's get worse MPG.
im stock and get 300mi+ b4 the idiot light comes on, never had below 18mpg
Old Mar 18, 2006 | 10:24 AM
X-AWDriver's Avatar
2nd gen Runners have a 3.0 and it generally gets worse gas mileage and has 30 less ponies so you get kicked in the nuts twice.
Old Mar 18, 2006 | 11:18 AM
Toyo-Mama's Avatar
Don't forget to count any discrepancies with over sized tires... my 33's have my numbers (both speedo and odo) off by about 18%, and consequently, my mpg figures as well. Even so, my gen1 3.0 (lifted with the 33's) only gets 14mpg, my old gen1 with stock tires gets 17mpg, and my gen2 3.0 got 15 before the thrown rod.
Old Mar 24, 2006 | 07:50 AM
amorphous's Avatar
yah, if you have 285s (metric 33"s) and your old size was a metric 31" - you need to multiply by 1.072 to get your "true" gas mileage. It might be better than you think!
aaron
Old Mar 26, 2006 | 04:40 PM
jwbehm's Avatar
14.5 mpg here on a stock 99 4Runner 4x4 manual. I think my tire pressure is messed up though. Hopefully it will be better once it gets warmer
