97 4runner 3.4ltr mpg??
Old Mar 26, 2006 | 04:44 PM
cancow's Avatar
I put more air in my tires and gained 2 mpg. I went from 16mpg to 18mpg mostly city driving.
Old Mar 27, 2006 | 02:42 AM
Toyo-Mama's Avatar
Those 16-18 mpg sounds about right... I wouldn't think you'd get much more than that as long as its stock. I've heard good things about the K&N air filter tho... that might boost your mileage. Otherwise, yeah... my (current) daily driver is only getting 13-14mpg. But you love on 'em anyways, right?
Old Mar 27, 2006 | 08:49 AM
theryanator's Avatar
What psi are you using?
Old Mar 27, 2006 | 11:24 AM
jwbehm's Avatar
What psi should i have my Michelin Cross Terrains at? They are all at around 29-30 now. Should I raise them up to around 33?
Old Mar 27, 2006 | 11:54 AM
  #25
X-AWDriver's Avatar
32psi is standard but I run my Nittos at 35psi.
Old Mar 27, 2006 | 10:06 PM
  #26
Runner003's Avatar
I run my good years at 60psi the max on them is 65psi cold, look at your tires to make sure. The psi is the fastest gas robber besides a clogged airfilter or even worst a clogged fuel filter..
Old Mar 28, 2006 | 02:42 AM
  #27
Toyo-Mama's Avatar
I run 33 Mud Terrains at 35 psi... still get 14 mpg in the city
Old Mar 28, 2006 | 10:51 AM
  #28
jwbehm's Avatar
I guess I will do 33 psi tonight, my max is 35 psi
Old Apr 3, 2006 | 03:54 PM
  #29
amorphous's Avatar
started running my "street" tires (32" a/t's) at 35 psi last tank full....
I just jumped up to nearly 17 mpg!
aaron
Old Apr 4, 2006 | 08:27 AM
  #30
Toyo-Mama's Avatar
aaron
whoa... on the 3.4 you got 17mpg? Not too shabby... My mileage is steadily coming up, now at 15mpg after some concentrated fuel rail/injector/ everything in between cleaner... but still w/ 33x12.5's... how silly my truck would look with conventional tires.... but with gas at $2.68 a gallon, well, I might make the concession...
Old Apr 4, 2006 | 02:08 PM
  #31
amorphous's Avatar
well, i *did* say "NEARLY" 17 - it's like 16.8 ...so...round up! And this was BEFORE I cleaned out the MAF!
and yah, going back to metric 32"s that are a/t's looks REEEEEALY lame compared to my 285 m/t's....but...saves the duckets. Saves wear on the m/t's too
aaron
Old Apr 4, 2006 | 02:34 PM
  #32
habanero's Avatar
Doing the formula I'm getting 18 1/2 mpg consistantly.....except the first week I did the ISR mod-17 that week. Prior to the mod I was getting 19+ but oh, that noise! I do about 30/70 highway/city driving.
I have Michelin LTX M&S on mine currently, no lift, pretty much stock.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
ryerye13
Jul 14, 2015 08:27 AM
