trouble with the diff breather mod
Old Feb 27, 2006 | 05:30 PM
99SR5's Avatar
so i did the diff breather mod and now sometimes when i put my truck in drive it feels like something is holding it back and somethimes when i give it gas frome a stop it feels like something slips like my gears are slipping or something. anybody know what could be happening
Old Feb 27, 2006 | 05:31 PM
Lone4runner's Avatar
a breather should not affect your truck like that. have you done any other mods?
Old Feb 27, 2006 | 05:45 PM
99SR5's Avatar
nope. could the emergancy brake cable be doing something
Old Feb 27, 2006 | 05:53 PM
only if you took the bracket off and then installed it in such away to pull on the line
Old Feb 27, 2006 | 05:59 PM
99SR5's Avatar
no... i didn't touch that. could the cold weather be effecting my fluid? i dont know... its kindof pissing me off.
Old Feb 27, 2006 | 06:06 PM
khaug's Avatar
Check to see if you've had a rear axle seal fail. This lets gear lube contaminate the brake shoes and they swell and bind the rear wheel(s). If you can see gear lube splattered on the inside of a rear wheel, this is most likely the problem.
This is a very common problem on 3rd gen 'Runners.
Old Feb 27, 2006 | 06:15 PM
99SR5's Avatar
i had them changed when i bought my truck. they were changed about a few monthes ago. but thats what it feels like.
Old Feb 27, 2006 | 06:22 PM
cold definitely affects our trucks but i guess its objective as to what is considred normal. i mean when its cold lie 5 degrees my truck is mad sluggish until it warms up after 15-20min worth of driving. hell it acts like that when it hits 30 degrees. As far as you going from a complete stop if it feels jerky it may be an early sign of a tps. nothing to worry about to you see a check engine light. bottom line i wouldnt worry too much yet. just keep an eye out for more symptoms
Old Feb 28, 2006 | 06:58 AM
99SR5's Avatar
sorry for the dumb question but whats tps. It doesnt only feel like that when its cold. its like my brakes are worped or something.
Old Feb 28, 2006 | 07:08 AM
TPS is throttle positioning sensor. no question is dumb its cool its possble and its just another option
Old Feb 28, 2006 | 07:10 AM
99SR5's Avatar
i doubt that. it just feels like my brakes are worped or something like that. could it be from hard braking?
Old Feb 28, 2006 | 07:42 AM
have you checked the shoes on your rear brakes?
Old Mar 1, 2006 | 06:16 AM
99SR5's Avatar
not yet. what should i look for. how would they look if they are messed up
Old Mar 1, 2006 | 06:28 AM
Localmotion's Avatar
look for a coating of axle lube, or any other kind of leaking.
Old Mar 1, 2006 | 05:36 PM
99SR5's Avatar
i just got the seals done a few months ago. they shouldnt be screwed up already.
Old Mar 1, 2006 | 06:05 PM
marreque's Avatar
i have the same problem, and it is the axel seals. i know you had the seals replaced but if the shoes were only cleaned it will still cause them to stick. remember they were contaminated with diff fluid.
Old Mar 2, 2006 | 07:46 AM
99SR5's Avatar
yeah but they said that they werent too bad. so i need new shoes? would i have to pay to get it done or would they cover it since they screwed up?
justdifferentials
14
Jun 11, 2017 08:36 PM
punks_is_4x4
May 31, 2016 06:03 AM
Boomer8404
Sep 10, 2015 09:01 AM
zz_denis
Sep 6, 2015 03:43 PM
128keaton
Sep 3, 2015 05:09 PM
