Vibration inside front diff carrier questions
Old Mar 8, 2006 | 10:37 AM
mjwalfredo's Avatar
Sorry to start yet another thread about my vibrations :cry:
I have checked a few manuals about the insides of the Front differential carrier but none show many details. I now believe my vibration is coming from inside the front diff. I replaced the CV axles after I noticed the seal on the driver's side was leaking fluid. The vibration is still there and now the new seal is leaking fluid. For about 4 years I rarely used 4wd on the truck and rarely changed the fluid in the front diff.
Is it a bearing that the end of the CV shaft goes into in the diff? Can I open the carrier and check it out without having to set up the gears before I put it back together?
I believe it is not the actual gears since only the left side is leaking fluid and the gears don't turn in 2wd drive just the CVs right?
If anyone has encountered a similar problem, can you share your experiences?
I get the feeling that I should just take it to my Diff guy and have him put in an ARB Air Locker while he has it apart.
Thanks guys.
Old Mar 9, 2006 | 09:15 AM
BruceTS's Avatar
you should be able to tear things down and replace the bearing, without much worry about having to re-shim the R&P, but I'd definately check the backlash after assembly.
Your second option is your best bet, if your planning on wheelin it.....
Old Mar 9, 2006 | 09:20 AM
JHupp's Avatar
The right side actually does turn while in 2wd. If you have add which is pretty standard from 96 on, the left side CV is disconnected from the front diff by means of an accuator, while the right side still spins with the gears and everything. Of course by right and left I mean your perspective if you were sitting in the driver's seat.
Old Mar 9, 2006 | 11:51 AM
mjwalfredo's Avatar
Oh wow, so the ring and pinion are turning because the right CV axle is connected to it? I am confused I think I am gonna get a used unit and then I will be able to take apart my current one and see how everything works. Maybe even learn how to set up a diff, that would be cool.
Old Mar 9, 2006 | 01:34 PM
eric-the-red's Avatar
The ring gear wont turn, but one side gear and the pinion gears will turn.
Old Mar 9, 2006 | 02:10 PM
mjwalfredo's Avatar
So, on the left side, what if anything is turned by the CV axle? I am pretty sure that is where my vib is coming from and that is why the oil seal keeps leaking.
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
TokyoD23
Jul 12, 2015 06:01 AM
