Timing belt tensioner problems
Old Mar 5, 2006 | 04:47 PM
SeanPritchard's Avatar
Ok, hopefully someone has experienced this before. I have now changed the Timing belt on my 91 Toy 4runner (V6) twice. Both times the belt has jumped time due to the tensioner coming loose. The Chilton manual recommends tightening the bolt, attaching the spring, then releasing the bolt to allow the spring to gain tension. The first time I had an immediate knocking followed by the belt popping off quickly. The second time I tightened the bolt enough to hold in place but the pulley was still movable. This time it lasted considerably longer (15 minutes) but wound up the same way. I am trying find out the correct process I must complete in order to get this thing back up and running. Should the tensioner bolt be tighter even though it doesn't appear to allow any movement? Obviously I am getting tired of making the same mistake and any help would be greatly appreciated.
Old Mar 5, 2006 | 05:01 PM
callmej75's Avatar
Make sure you put the spring back on the tensioner with the bolt loose. then let the spring put tension on the belt and tighten the bolt.
Old Mar 5, 2006 | 05:25 PM
Thanks for the quick reply, how tight should the bolt be in your estimation? I am worried about making it too tight but it is clear I haven't been tightening it enough up until this point. Is there a too tight?
Old Mar 5, 2006 | 05:31 PM
callmej75's Avatar
No prob....FSM says 25ft lbs. I would watch "strong arming" it because once you break a bolt it only spirals downhill before wrenches start flying Once you have the belt lined up and all marks match up, it should be pretty hard to get that spring latched that holds the idler firmly against the belt. That alone should be enough tension.
Old Mar 5, 2006 | 05:57 PM
The spring should be enough tension? The spring has been attached the whole time and its still jumping. I am just baffled as to why this keeps happening. I expect the bolt should be firmly tightened, like you would a typical bolt. Not cranked on but definitely solid, is that right?
Old Mar 5, 2006 | 06:07 PM
callmej75's Avatar
Yeh that sounds about right. Not sure why its jumping off...hopefully someone can jump in and offer some more advice. Sorry thats all I got..
Old Mar 5, 2006 | 06:13 PM
Thanks very much for your input, I really appreciate it
Old Mar 6, 2006 | 08:01 AM
eric-the-red's Avatar
A little blue Loctite on the bolts might help, and is it possible that the spring is stretched and no longer has enough tension.
Old Mar 6, 2006 | 08:10 AM
Thanks Eric, thats what we were thinking too. It seems odd that a spring wouldn't just come with a new tensioner considering the constant strain it is under. I am about to start pulling it apart again (third time in four days, ugh) and this time I am using a torque wrench just to be safe. I think I am leaving the bolt too loose and it is working itself out as the motor vibrates
Old Mar 6, 2006 | 09:28 AM
And I found this picture on someone elses thread, this looks exactly like my setup. The bolt in question is the tensioner bolt
Old Mar 6, 2006 | 09:39 AM
callmej75's Avatar
When I had my timing belt on and tried pulling that spring with a pair of pliers, it must have slipped 7-8 times before I got it latched. Under alot of tension! You might want to replace the spring or for right now try to pry the tensioner over, not REALLY tight, but tight enough for tension purposes and tighten the bolt at the same time you are prying on it. Should get you going instead of waiting on a new spring.
Old Mar 6, 2006 | 05:32 PM
Thanks j75, I got it going this morning and managed to drive around all afternoon. I think this nightmare may be over. Thank you very much for all the help, I desperately needed a second opinion
Old Mar 6, 2006 | 08:15 PM
callmej75's Avatar
no problem! glad ya got it going...
layifioren
10
Jul 6, 2015 02:26 PM
crazypaint
Jun 23, 2015 03:27 AM
Mohamed
17
Aug 21, 2002 12:54 PM
TRD 4RNR
Jun 21, 2002 05:09 AM
