were the tacomas equipped with the 2.4 engine?
Old Mar 14, 2006 | 08:44 PM
Brendan's Avatar
i've always been under the assumption that the 2.4 22re ended production with the end of the 1994 (early 95) trucks, but i've been seeing for sale ads with 2.4 engines in the description. is it a different 2.4 or is it just false info? i thought it was just 3.4 and 2.7 offered in the tacoma years.
Old Mar 14, 2006 | 09:00 PM
JDMHN8's Avatar
2RZ was offered in 2WD trucks.
Old Mar 14, 2006 | 09:07 PM
marko3xl3's Avatar
Originally Posted by Wikipedia.com
2RZ-E
The 2RZ-E is a 2.4 L (2438 cc) version built in Japan. Bore is 95 mm and stroke is 86 mm. Output is 142 hp (106 kW) at 5000 RPM with 160 ft·lbf (217 N·m) of torque at 4000 RPM.
Applications:
* 1995-2004 Toyota Tacoma 4x2
* 199x-2004 Toyota Hiace
This is the predecessor of the 3RZ-E which was the 2.7L engine for the Tacoma's and some 3rd gen 4Runners.
Originally Posted by Wikipedia.org
The 3RZ-E is a 2.7 L (2693 cc) version built in Japan. Bore is 95 mm and stroke is 95 mm. Output is 150 hp (112 kW) at 4800 RPM with 177 ft·lbf (240 N·m) of torque at 4000 RPM.
Applications:
* 1995-2004 Toyota Tacoma 4x4
I know Wikipedia says the 3RZ-E wasn't used the 4Runners, but it was...1996-2000
Old Mar 14, 2006 | 09:09 PM
Glenn's Avatar
The 22RE and 2RZ-E are different engines. Different bore/stroke, different heads, etc, etc.
smthwsn357
May 1, 2024 07:28 AM
Regency
20
Jan 3, 2020 07:43 PM
TokyoD23
Jul 12, 2015 06:01 AM
akaphilly
Jul 9, 2015 02:18 PM
AaronM
Jul 8, 2015 07:15 PM
