Timing Belt
Old Mar 11, 2006 | 02:03 PM
Timing Belt
I am changing the belt on my 99 4runner w/3.4 I have everything apart & started to put it back together but I can't get the belt on. I have the compression tool that I used w/ pin but it seems like the belt is to short! Any suggestions would be helpful. Thanks
Old Mar 11, 2006 | 05:18 PM
Ironmike4x4's Avatar
Wrong belt maybe? It wouldn't surprise me at all especially if you get it from any other place than a stealership.
Old Mar 11, 2006 | 06:18 PM
fireteacher's Avatar
how long did it take you?
did you do the waterpump?
are you very mechanically inclined?
what did you use for ref?
Old Mar 11, 2006 | 06:33 PM
bigacuralvr's Avatar
NO! You have to line up the belt at the bottom crank pulley first, take off the top idler pulley, line up the 3 lines (Crank pulley, 2 top camshaft pulleys, then, put the top idler pulley on. I did the same thing, got all pissed off, then realized my mistakes!! I would almost gaurantee that is your ptob. Good luck!!
Old Mar 12, 2006 | 04:43 AM
To answer your questions-I got all my parts @ Toyota dealer-- bibacuralvr, I will try taking the top idler pully off as I did not! I will let you know if it works, Thanks
Old Mar 12, 2006 | 07:16 AM
bibacuralvr, You were right! I took off the top idler & it fell tpgether. Now I feel like a Dumb A$$ Thanks a lot for you help.
Old Mar 12, 2006 | 12:16 PM
Hey, it happens to more people than you know.
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
