Can I use a MSD 6?
Old Sep 26, 2005 | 08:47 PM
jimboscott's Avatar
Can I use a MSD 6?
I've got a 98 taco with 83,000 miles and want to find more power. I already have exhaust (including downey header) and intake. Can I run a MSD 6 system with my 2.7? Thanks
Old Sep 26, 2005 | 08:49 PM
jimbo74's Avatar
you can, however don't be surprised if you aren't getting all the power out of it you are expecting.... the reason being the stock ignition is pretty good and not a weak point of the vehicle.... might want to look into a cam or a computer controller for more performance
Old Sep 26, 2005 | 09:17 PM
kyle_22r's Avatar
you probably won't gain any power with the MSD system. as jim said, toyota's ignition really is a good design. are you running oversized tires? regearing will make the biggest difference in power.
for engine mods, all there really is left to do is head porting and polishing, and maybe a set of performance cams.
Old Sep 27, 2005 | 05:44 AM
MTL_4runner's Avatar
You can certainly try it but I seriously doubt you'll see any noticeable engine gains.
Best bang for the buck would be a S/C for that motor (I am pretty sure they make one for the 2.4L).
Other cheap stuff includes opening up the airbox (deckplate), amsoil air filter, headers (you did already), high flow cat, etc.
Old Sep 27, 2005 | 08:53 AM
jimboscott's Avatar
The motor in my truck is the 2.7, and it hasn't had a tuneup in about 50k. I'm running 31x10.5 BFG ATs. A few of you mentioned swapping cams and or computer mods. Who sells these and where can I find them? Also, any clue as to how much the cam swap would set me back? Thanks again.
Old Sep 27, 2005 | 10:38 AM
PO2SIMS's Avatar
For computer mods go HERE.
For pricey cams go HERE
For cheaper cams go HERE
You can get cam gears at both places too.
Old Sep 27, 2005 | 06:29 PM
jimboscott's Avatar
Are there any pulleys made for my truck? How about e-fan conversions? I'm kinda looking for some smaller things to do that will add some power to help push some 33s.
Old Sep 27, 2005 | 08:53 PM
jimbo74's Avatar
changing gears will be the best bang for the buck.... seriously.....
an electric fan will help maybe a few hp, but thats it, pullies if they are even made for the 2.7 might help out hp a bit, but to push 33s you need torque, there is no substitute for it...... gearing is the best bet
Old Sep 28, 2005 | 05:27 AM
I have to agree with Jim....either you add more torque (via S/C and the like) or you bring the engine back into optimal torque range (via gearing, etc). Ideally you do both but that costs big $$$$$. You aren't going to push 33's very easily by just adding a few HP here and there.
Old Sep 28, 2005 | 10:22 AM
PO2SIMS's Avatar
I just have simple bolt on's and I push 33x10.50's very easily w/ 4.10's. The 2.7 3RZ really wakes up when it's able to breath freely. My runner now is faster w/ the 33's than stock w/ the 31's. Some engines respond well to bolt on's. Gears are a quick way to regain lost power or just use more, but are not always the answer. If he is concerned about gas milage than gears are the wrong way to go. Simple bolt on's will improve mpg and give good power. Stuff like the e-fan will barely give better hp, but will give better mpg #'s and reduce strain on the water pump. Just remember there are different angles to look from when modifying a vehicle.
Old Oct 14, 2005 | 04:36 AM
BOSTON4RUNNER's Avatar
you need the DIS digital MSD
I use MSD in everything about to wire one up for my 3.4 liter
they work great and in the many drag race applications I have used them for, usually pick up 2 tenths in the quarter
def will pull harder, especially at the higher RPMS
Old Oct 14, 2005 | 05:40 AM
Churnd's Avatar
Mainly all you'll notice is a slightly better pull at WOT or highway driving.
Old Oct 14, 2005 | 06:37 AM
midiwall's Avatar
If you do decide to try the ignition route, check into Ignition Systems as well. I've been running their Plasma Booster on a 3.4L for a while with good results.
But... All the other folks have better ideas.. there are better things to spend money on at this point.
MadMax48
Mar 3, 2020 10:33 AM
JHalcyonM
Sep 14, 2015 01:10 AM
phorensic
Mar 8, 2006 09:30 AM
