what is my liter on 94 4runner?
Old Sep 20, 2005 | 09:51 PM
arielb1's Avatar
I have a 1994 4runner V6 4X4 with 110k miles. Engine runs great. I am the original owner. Never knew what liter meant and did not care much till now.
I am purchasing a pop-up trailer (camper). I was asked what liter engine I have since the trailer will be 2500lbs. I use to pull two jetskis without a problem, but I think the trailer loaded will be much heavier. Will my truck have a problem pulling this trailer? Do you know what the liters is and how do I go about finding out.
Thank you for educating me.
Ariel
Old Sep 20, 2005 | 10:09 PM
Tomsriv
Guest
Posts: n/a
It should be a 3.0 Liter and if you tow a trailer with it, it will probably blow a head gasket and ruin your engine. Just go easy on it.
Old Sep 21, 2005 | 12:27 AM
jimbo74's Avatar
a liter is a unit of measuremnt in the metric system
in a vehicle its the displacement of the engine
a ford for example would use a 302 cubic inch (sae) engine as a 5.0 liter (metric)
Old Sep 21, 2005 | 12:52 AM
rocket's Avatar
If it's a V6 then it's a 3.0 liter.
Old Sep 21, 2005 | 02:28 AM
dwh91102's Avatar
Man thats about the worst information I've ever seen given on here. Ariel, you didn't mention if the 4runner was auto, or manual. If the 4runner is a manual you'll have no problem towing the camper, if its an auto make sure it has a good tranny cooler installed, especially if towing long distances. As for you liter question yes your motor is a 3.0L which is 183 cubic inches. If you want to figure a engine out its 61 cubic inches per liter. Go camp and have fun
Old Sep 21, 2005 | 03:42 AM
ChickenLover's Avatar
Your question is vague at best. Personally, I do not like to tow more than 2k lbs with my 3.0 auto. I live in a very mountainous region. Under 2k, I can maintain highway speed just about anywhere (my engine is built up quite a bit). I have towed over 5k lbs around town without a problem, but would never take that kind of load on the highway. As dwh said, if you have a manual you'll be better off. If you are towing on flat roads, you'll be just fine either way.
Old Sep 21, 2005 | 04:02 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I used my '90 3.0 liter V6 (manual tranny) to pull a 2800# camper and it was well over the 3000# limit of my trucks' towing capacity after it was loaded with gear. I would have hated to to have been the guy behind me on hills. The flat-out trips were a breeze, but the trips to the mountains made me crap my pants. It helped a tiny bit when I put premium in a few fill-ups prior to the trip. Just take your time and watch your braking distance.
Old Sep 21, 2005 | 12:03 PM
Flamedx4's Avatar
:pat: Jeez.
I pulled a pop up (Apache, about 2000 lbs) all over Oregon, Wa, CA, pulled a decent sized sailboat (with trailer and gear, about 3500 lbs but it's 9 feet high and really affected by Wind) all over the same places, with my 22RE 4runner with never an issue. Don't sweat it with your 3.0 - they pull tent trailers with volkswagens fer goshsakes!
Sure it'll slow you down on hills, sure it will increase your stopping distance - that's all part of towing a trailer... you don't need a deisel dually for a tent trailer...
Old Sep 21, 2005 | 12:20 PM
celica's Avatar
OK I have a 92 with the V6. The rated towing capacity oer the manual is 3500lbs. A little lent trailer will be a breeze. My 4runner has spent most (well over 60%) of its life either towing or plowing snow (i have 230,000 miles on it). It tows just fine, yes itis slow on hills, but what isn't when you are dragging the weight of a car behind you. I have towed bobcats & landscape trailers with no problems. These are both areound the 5000lb mark. I wouldn't recommend you tow more than the rated weight as if you get caught it is a big fine and insurance may not cover you inan accident. The dealer selling the trailer doesn't know much. It isn't really the size of motor that counts, it is the towing capacity. I also tow a seadoo trailer with 2 seadoos on it. The weight if it isn't much different than the trailer you are looking at. I also to w a 5x10 trailer for work woth areounf 1000lbs in it on a regular basis (approx 2200lbs), no problem. The only thing is if your rear springs are weak you will have some sag in the back end.
Matt
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
v_man
Jul 23, 2015 04:01 PM
Cplmike
Jul 8, 2015 08:47 PM
