wheel question?
Old Jun 16, 2008 | 03:23 PM
PatHLC128's Avatar
wheel question?
I found some wheels i like but i dont quite understand all the sizes. I have an 02 4Runner sport with stock rims and 265/75/16 BFG all terrains. Which size from the link do i need to order?
http://www.4wheelonline.com/Products...oductId=127570
also any input on these wheels is good too, I would assume anything from pro comp would be good quality. 90% of my driving is on road (i live in suburban new york) and any off roading i do definitely doesn't involve rock crawling btw. thanks guys
Old Jun 16, 2008 | 04:24 PM
norcalsvx's Avatar
i would get the 16x8 6x5.5
Old Jun 17, 2008 | 08:12 AM
PatHLC128's Avatar
any other input, i really want to know for sure that theyll fit my tire/car.
Old Jun 17, 2008 | 09:57 AM
michalik_piotr's Avatar
your stock wheels are 16x7, on a 8" rims u usually run a 275 not a 265 so i don't know if a 265 will fit and if so, if it will look funny.
Old Jun 17, 2008 | 10:29 AM
Rock Slide's Avatar
I'm running 265/75s on 16x8 wheels...they look fine to me. It's the equiv of a 32x10.50. The diff in width between a 265 & 275 is neglible.
Old Jun 17, 2008 | 11:31 AM
huh, thats good to know....i trust your knowledge/answers rockslide. do you have pics? reason i said that is b/c the LC 16x8 wheels i got with 275/70 look way wider then my oem 5 stars with 265/70.
Old Jun 17, 2008 | 12:43 PM
cackalak han's Avatar
So you're basically looking for pretty much an on-road set of wheels? I don't know how they would look on 3rd Gens, but those 18" rims on the 4th Gen Limiteds really look good. I think 18's are a good-sized street wheels without looking like a ghetto-thugged out SUV rolling 23's.
Old Jun 17, 2008 | 12:55 PM
Rock Slide's Avatar
The 275/70s on 16x8 wheels should be a good bit wider than stock 265/70s on 16x7 wheels, but more so b/c of the wider new rim than the new tire. Yes, the 275s will magnify the difference, but they are not the sole culprit for causing the difference to look so noticable.
A combination of both larger rim and tire cause them to be wider, but I believe the rim is causing more of the stance than the tire alone. I'd say the rim is causing about 70% of the wider stance and the tire makes up the remaining 30% (Just guessing here).
For compairing tire sizes, check out this model:
http://www.miata.net/garage/tirecalc.html
And here's another good one too:
http://www.wickedbodies.net/Tire-Size-Calculator.htm
For pics of my current 265/75s on 16x8 wheels vs my old 265/70s on 16x7 wheels, check out my Install thread. Plenty of before and after pics here:
https://www.yotatech.com/forums/f2/n...s-pics-125975/
Old Jun 17, 2008 | 01:05 PM
PatHLC128's Avatar
im not trying to get new tires, my BFGs are a couple months old. i just want to know if those wheels (16x8 with 6-5.5 bolt circle) will fit on my truck with the tires i already have.
Old Jun 17, 2008 | 01:08 PM
Gotcha. I actually like the 02 wheels. But if you must get new wheels in 16's, I really like the OEM offerings. 99-00 5-star's or FJ80 LC's.
Old Jun 18, 2008 | 10:55 AM
Hirox's Avatar
Mine is just look like this.
Procomp 16x8 6x5.5 offset 0 with 265/75R16
I think you will be fine with it.
glowz825
Jan 25, 2022 09:28 AM
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
