What's this part
Old Jun 28, 2008 | 10:34 PM
wormhole's Avatar
What's this part
Probable a stupid question but what is this part?
Old Jun 28, 2008 | 11:28 PM
Elton's Avatar
some kind of dampener counter balance thing ???
Old Jun 28, 2008 | 11:58 PM
Lysmachia's Avatar
Originally Posted by hytenor
that is your harmonic balancer....it keeps your truck well balanced and in harmony with itself :p
take it off and drive around for a while and you'll see what it does
Looks like it is right next to your cat and transfer case or transmission from underneath the truck looking towards the front. Correct??
Tranny mount of some (WEIRD) sort???
Old Jun 29, 2008 | 01:09 AM
HAVOC's Avatar
It's a vibration damper similar to the one that is on the front of the crankshaft. It's bolted to the t-case to reduce driveline vibrations.
Old Jun 29, 2008 | 04:53 AM
dirtoyboy's Avatar
Its a harmonic balancer
Old Jun 29, 2008 | 05:14 AM
dirtoyboy's Avatar
From Wikipedia
"A harmonic balancer (also called crank pulley damper, crankshaft damper, torsional damper, or vibration damper) is a device connected to the crankshaft of an engine to reduce torsional vibration.
Every time the cylinders fire, torque is imparted to the crankshaft. The crankshaft deflects under this torque, which sets up vibrations when the torque is released. At certain engine speeds the torques imparted by the cylinders are in synch with the vibrations in the crankshaft, which results in a phenomenon called resonance. This resonance causes stress beyond what the crankshaft can withstand, resulting in crankshaft failure.
To prevent this vibration, a harmonic balancer is attached to the front part of the crankshaft. The damper is composed of two elements: a mass and an energy dissipating element. The mass resists the acceleration of the vibration and the energy dissipating (rubber/clutch/fluid) element absorbs the vibrations.
Over time, the energy dissipating (rubber/clutch/fluid) element can deteriorate from age, heat, cold, or exposure to oil or chemicals. Unless rebuilt or replaced, this can cause the crankshaft to develop cracks, resulting in crankshaft failure.
There has been a trend at times by some "performance enthusiasts" to remove the harmonic balancers on their cars, usually when the balancer is attached to the crank pulley. The argument is that they aren't necessary and their mass reduces the performance of the engine. Others[who?] argue that this is not worth it, because the danger of damage to the engine from the vibrations the damper is intended to prevent is too high. Certain cars, however, do not come equipped with an external balancer on the crank pulley, and as such, can have the pulley replaced with a performance oriented product.
While net engine output can be increased without harmonic balancers, in professional race cars harmonic balancers are still commonly equipped, for reasons ranging from safety concerns to regulations. Almost all modern car manufacturers, even "performance" car makers and specialty tuners, include a harmonic balancer on their vehicles, and removal voids vehicle warranty.
Retrieved from "http://en.wikipedia.org/wiki/Harmonic_balancer"
Old Jun 29, 2008 | 05:20 AM
CJM's Avatar
CJM
Its just a vibration dampner, nothing special. I doubt it would even matter if it was on there or not.
Old Jun 29, 2008 | 05:27 AM
wormhole's Avatar
Thanks for replies.
Old Jun 29, 2008 | 04:10 PM
hotlavaaaa's Avatar
Yeah, Toyota decided to put it on just for the hell of it.
Old Jun 29, 2008 | 04:13 PM
DeathCougar's Avatar
Harmonic balancers, as per your posted description, mount on the crank. Thats on the back of the tcase. But you are still correct, it is designed to balance out the harmonics of the drivetrain.
Old Jun 29, 2008 | 07:25 PM
toy_tek's Avatar
Isn't that a muffler bearing?
Old Jun 29, 2008 | 07:28 PM
no sheesh
Thats the blinker fluid container
Old Jun 29, 2008 | 08:48 PM
wormhole's Avatar
Originally Posted by DeathCougar
no sheesh
I was wondering where that was at haha
Old Jun 29, 2008 | 10:21 PM
Often times its confused with the Muffler bearings, or even the knutsen valve!
Old Jun 30, 2008 | 10:35 AM
TexanTaco's Avatar
I think I blew out the Knutsen valve on my truck.....HELP!!!!11!!!!!!!
Old Jun 30, 2008 | 10:41 AM
dirtoyboy's Avatar
I think they make a difference...I always leave mine on......
Yes, toyota did put it there for a reason....apparently Toyota is one of the only auto makers to do this....confuses the hell outta some Domestic mechanics lol
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
