need help with spacers
Old Jul 6, 2008 | 12:41 PM
VA4runner98's Avatar
Exclamation need help with spacers
hey guys i just recently added new front and rear bumpers and i waited about 6 weeks to see where it all ended up settling to. the front is at 37.5 and the rear is at 39.125, so now i got a diffrence of like 1.625, a 1 3/4 inch spacer would do the trick...what can i put on top of my ome setup and could i add two small spacers together on top of each other, like a 3/4 and 1inch to gain a full 1 3/4 inch per side ...im really stuck and dont know the best way to go about this.. thanks in advance...and yes i have searched
Old Jul 6, 2008 | 01:28 PM
Fink's Avatar
Are you already running top out spacers on your OME lift?
Fink
Old Jul 6, 2008 | 02:28 PM
no i dont have any...just the springs and shocks...im tryin to get her even
Old Jul 6, 2008 | 03:18 PM
kmcaprice14's Avatar
what springs do you have up front? 881s?
Old Jul 6, 2008 | 03:29 PM
Fink's Avatar
Can you give us details of your lift and exactly what you are running?
I had the Tundra/OME lift (search for "Tundra/OME") and I had one top out spacer and I was perfectly even. You might need to add two sets up front to make her even.
Fink
Old Jul 6, 2008 | 04:05 PM
or go to taller springs up front with a spacer (882s, etc)
Old Jul 6, 2008 | 06:49 PM
i have heavy duty all around... i think thats the 882s up front... i just have the springs ...no trim packers or anything
Old Jul 7, 2008 | 12:53 PM
need some advice guys ... im a little lost
Old Jul 7, 2008 | 01:15 PM
emptypockets's Avatar
You must have 881's up front. There's no way that 882's would be that much shorter. Most sites call the 881's heavy duty and don't even recommend the 882's for 3rd gen 4Runner applications. But, I've got a set of 882's ready to install now and they'll probably match up with LC springs in the rear, which are longer than OME's. Right now, our measurements are almost exactly the same up front and I'm getting another 1/2" in the back, so it will be interesting to see what the 882's do in terms of lift.
If you're running the 881's, you can most definitely run a spacer with them. Toyteclifts.com sells a 3/4" lift spacer specifically for that. Please post more specific lift information so we can help you better!!
Old Jul 7, 2008 | 04:00 PM
Fink's Avatar
Odds are you have the 881's up front.
Have you tried searching for "Tundra/OME lift"? There is a ton of talk out there about how many spacers are needed and for which applications. I would spend some time researching it on here - you may get more results and less junk if you use the advanced search feature.
Fink
Old Jul 7, 2008 | 04:12 PM
crolison's Avatar
dang your getting a good amount of lift out of your 891's, I got them and I am only at 38", but i have a crap load of stuff in the rear
Old Jul 7, 2008 | 05:13 PM
yeah... the actual specs of your lift would help a bit
Old Jul 7, 2008 | 07:19 PM
is there a way i can tell what springs i have?... im at school and i dont have any of the boxes...does it say on the spring?
Old Jul 7, 2008 | 08:59 PM
Fink's Avatar
It won't say on the spring - not sure how else you can tell.
I know the 881's are supposed to give about 1.75-2" of lift...I don't know how much different the 882's are. I would imagine either way you could run them with a spacer (ride quality will suffer though).
Fink
Old Jul 8, 2008 | 04:07 AM
From the research I've done, the 882's give ~2.75-3" of lift on their own without spacers. With the amount of lift you're getting, it seems almost certain you have the 881's. I wouldn't do spacers on top of the 882's because of CV issues. If you can confirm you have the 881's, spacers would be fine.
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
