Changing axle shafts
Old Jul 27, 2003 | 06:02 PM
93toy's Avatar
A read a post (on this site) the other day where someone said it was just as easy (or easier) to change the entire axle shafts as what it was to replace a torn boot. Well, I picked up the lifetime warranty axle shafts from Autozone but I have a question before I tear into it....the Haynes manual says you have to rip into the manual locking hub to remove the outboard end of the shaft, is this true? I know there are 6 bolts for the inboard end, but can anyone offer any detail as to what's involved with the outboard? Any help would be appreciated.
Old Jul 27, 2003 | 06:49 PM
keisur's Avatar
Re: Changing axle shafts
very interesting.
metal22lica's Avatar
you do have to take off your hubs and take off an snap ring that hold the shaft into the hub/wheel assembly..
Old Jul 27, 2003 | 09:52 PM
Firefyter-Emt's Avatar
Yup, easy to yank the hub.. Remove that c-clip. Now here is another tip, Unblot the lower ball joint at the control arm (just 4 standard bolts) this will not harm the ball joint and it gives you plenty of room to work with, BTW, I left the stock bolts just the way they were.. Some people hammer them out to make swaps eaiser.. I think it is a lot eaiser to remove the 4 bolts at the ball joint. Also, lock the hubs and before you jack it up, break the nuts to the shaft free first.
Old Jul 7, 2008 | 03:42 PM
highridinyota's Avatar
hes got it down to a science.easiest way ive found
Old Jul 8, 2008 | 04:33 AM
toy_tek's Avatar
This thread is so old the OP has a 3rd gen in his sig now.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
polo451
13
Nov 20, 2016 07:49 PM
A2theK
Jan 10, 2016 10:18 AM
Backcountry411
Jul 24, 2015 08:06 AM
