99+ Headlights
Old Jul 2, 2008 | 09:42 AM
98runner210's Avatar
99+ Headlights
So are all teh aftermarket 99+ headlights the same? I heard the ones on eBay and even the ones from Burtman have crappy patterns...is this true?
Old Jul 2, 2008 | 09:58 AM
cackalak han's Avatar
Just try to find some OEM units from ebay or your junk yard. I wouldn't trust aftermarket headlights.
Old Jul 2, 2008 | 10:11 AM
dirtoyboy's Avatar
Buy the cheapest HIDS you can find on ebay!
I have them and they are fawesome...they blind all the other retarded drivers on the road! highly recommended
Old Jul 2, 2008 | 10:24 AM
You're getting way too carried away with all of this. Don't you have some tail lights to paint?
Old Jul 2, 2008 | 10:28 AM
dirtoyboy's Avatar
I do..I do..
and its not the tail lights...its the headlights....
I ran out of black paint after the 8th coat! dang it!
Old Jul 2, 2008 | 10:32 AM
Ritzy4Runner's Avatar
X2
That is how I did my headlight upgrade, I found mine in two different wrecking yards 4 months apart. Complete units for everything you need, light, housing(bucket), mounts, rubber boot and lamp. Be sure to get the lamp rubber boot too as your 96-98 lamp boots will not fit properly I tired and they just will not give you the proper seal.
I got both of my 99+ head lights for less then $50 total. Also, if you find a complete unit and one of the mounting tabs is broken, just see if the yard will sell it to you for a reduced price as you can use your OEM bucket. Even if the only thing there is the glass lense pick it up as everything is a direct swap(except for the rubber boot)! That is what I did as I was able to get both of mine with damaged buckets for $20 each, then I just disassembled the lamps and buckets, installed the 99+ lamps in my OEM buckets and reinstalled them in their locations. REALLY EASY to do! If you have any quesitons, check my write up on the install here: https://www.yotatech.com/forums/f2/9...l-98-a-145621/ And if you still have questions, just ping me and I will be happy to answer them for you! good luck!
Old Jul 2, 2008 | 10:35 AM
Originally Posted by dirtoyboy
I do..I do..
Try Herculiner. Not the spray, but the roll-on. You get more even, thicker coats.
Murdurrd Out!
Old Jul 2, 2008 | 10:42 AM
dirtoyboy's Avatar
Murdurrd Out!
You're killin me over here kid!
Old Jul 2, 2008 | 11:51 AM
Elton's Avatar
i found a decent set of oem headlights from ebay for less than $100 dollars
Old Jul 2, 2008 | 07:46 PM
Fo_SheeZy's Avatar
Yeah make sure they are OEM, those aftermarket look-alike OEM have horrible beam patterns!
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
