new tires. one rubs
Old Jun 20, 2008 | 07:52 AM
Phat Ham's Avatar
new tires. one rubs
I put 265/75-16 Terra Grapplers on my '96 4Runner (running boards removed), got an alignment, and now the right front tire rubs when I have the wheels turned to the right and go over a bump, driveway, etc. Only the right side rubs. The left tire has what looks to be plenty of clearance with the wheels turned to the left, but the rear of the right tire has almost no clearance with the steering wheel turned one turn to the right. This is strange. The alignment numbers are within spec and neither the tire shop or alignment shop mentioned anything being bent. What do you guys think could be the cause?
Old Jun 20, 2008 | 08:03 AM
4x4mike's Avatar
Guest
Has your 4runner been in an accident? Measure a few different places on both sides and see if they are the same. Things like the body panels and bumper. It could be that they are off a little and aren't noticeable until you stuff a big tire in there. Do you have a lift? If not maybe it's time to get one. I think that if you have problems on the street you'll have a heck of a time offroad.
Old Jun 20, 2008 | 08:31 AM
TexanTaco's Avatar
265/75-16 should fit without a lift right?
Old Jun 20, 2008 | 08:54 AM
michalik_piotr's Avatar
got the same size tires (revos) yeasterday and no issues at all w/o any lift on 2000 4runner. i've read on here a lot of people saying that tire will fit w/o any issues. something is off with your truck i'd say.
Old Jun 20, 2008 | 09:06 AM
Phat Ham's Avatar
yeah I'm thinking the same thing. The left tire has no rubbing at all. Only the right does. Something must be bent or the body on crooked or something.
If I take a BFH to the wheel well of the right front tire am I going to hurt anything?
Old Jun 20, 2008 | 09:08 AM
woodendude's Avatar
I have 31"x10.5 on my stock suspension, no lift 95 4Runner with no issues at all.
Old Jun 20, 2008 | 10:09 AM
probably not, trim, pound or whatever you need to get it not to rub. that is putting a band aid on a deeper problem abviously and "fixing" it w/o getting to the root of the problem but....if it aligned straight and drives fine, i'd say go for it. prolly cheaper and faster.
Old Jun 20, 2008 | 10:22 AM
Phat Ham's Avatar
the thing has 185k on it and is kind of a beater, so while it would be nice to fix the problem at its root, it's also probably not worth the cost (I'm guessing not cheap).
Old Jun 20, 2008 | 10:25 AM
X-AWDriver's Avatar
Tired coils and/or shocks?
Old Jun 20, 2008 | 10:40 AM
Phat Ham's Avatar
could be. Does anyone have measurements for standard ride height?
Or a simpler question to answer: With the 4Runner empty, should the left and right side be at the same height? Or is the left supposed to be slightly higher?
Old Jun 20, 2008 | 11:39 AM
4biker's Avatar
Do you have stock wheels? My aftermarket wheels' backspacing makes my 265/75/16's rub on my Limited's plastic add-ons, even with a mild lift - it's only on one side as well.
Old Jun 20, 2008 | 11:42 AM
Phat Ham's Avatar
yes wheels are stock. I don't have a lift, though the suspension may not necessarily be original.
Old Jun 20, 2008 | 12:41 PM
Phat Ham's Avatar
ok went outside and measured the height from ground to the middle of the lip of the fender. on the left I got 35.5 inches and on the right 34 3/4 inches. This is with nobody in the 4Runner. Is the 3/4 inch difference there to account for the weight of the driver, or is it not supposed to be there?
Also, the spot where the right tire is rubbing is the rear most part of the tire. In other words, if you were a passenger sitting in the front seat and stretched your foot out, the other side of where your foot is is where it's rubbing. Where a mudflap would mount. Probably easier to explain with a picture but I don't have a camera at work.
It seems like the right wheel is about 1/2 inch further toward the rear or the vehicle than the left wheel. hmm.
Old Jun 20, 2008 | 01:59 PM
clever thinking on the suspension part but this is not a nascar, suspension should be level.
Old Jun 20, 2008 | 02:36 PM
Fo-runna's Avatar
Also, try measuring from the center of the wheel to the fenders all the way around to get a better idea of where the wheel is positioned in the wheel well.
Old Jun 20, 2008 | 03:28 PM
n16ht5's Avatar
bizzarre... my 33x12.50s barely rub at nearly full stuff.. stock FJ rims
(maybe diff offset?)
I had 265s before and they barely came close at full stuff and didnt touch - stock
Maybe one of your A arm brackets has been bent ? (somnone hit a curb or something really hard?) try measuring along the frame parts where everything is on each side.
Old Jun 20, 2008 | 04:35 PM
Yota Runner's Avatar
Why are people with 2nd gens trying to help him with tire rub problems
Nothing in the suspension or body are the same so its totaly irrelevant
Any way...I had some minor rubbing on the right side with my 265 bfg all terrain tires and just pounded on the pinch welds a bit. Could just be that your springs and shocks are just tired. My measurements are about 35" from ground to the bottom of the Sr5 flares. Think of it this way, now you have an excuse to lift it.
TheBFA
Feb 15, 2020 06:55 AM
kbpickens
Oct 2, 2015 03:37 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
langry345
Sep 14, 2015 03:36 PM
