3.4L Idle issue
Old Jun 12, 2008 | 10:12 AM
TxDox21's Avatar
3.4L Idle issue
About a month ago I replaced the fuel filter thoroughly cleaned the Throttle body, MAF, cleaned the air filter and then reset the computer on the 4Runner and it ran better than the day I got it. A week ago, I noticed that it was idling a little low around 600 rpm in drive.
Today I decided to look at the throttle body to make sure it was still clean and it is. I then disconnected the battery to reset the computer again to see if it helped. Now I get the following rpm readings
In park w/ Air cond.: 900(normal)
In Park w/o air Cond: 500-700
In Drive:400-700
My RPMs are all over the place. I drove about 5 miles on it and when I would come to a complete stop, the rpm would go down to 400 and I would have to give it gas to keep it running.
Anyone have any ideas on what is happening? My $runner has 85,000 miles
Old Jun 12, 2008 | 12:57 PM
surf4runner's Avatar
not 100% on what 'normal' is but i idle at 600-650 under most conditions (a/c, D, P)
02 2wd
check for any vacuum leaks.
Old Jun 12, 2008 | 01:27 PM
j-man's Avatar
sometimes it takes 50 miles or so of driving for the computer to re-adjust to normal.
Old Jun 12, 2008 | 01:31 PM
TxDox21's Avatar
02 2wd
I was under the impression that 900 was "normal" for being in park and that around 700 was "normal" for drive with the a/c
I could be wrong though
Old Jun 12, 2008 | 01:55 PM
auto's usually do idle higher w/o a load(P or A/C on) mine doesnt vary much. then again... im not normal
Old Jun 12, 2008 | 03:33 PM
BajaRunner's Avatar
Honestly, you're numbers look normal. With the AC ON it should have higher idle.
If you're getting a low idle when the engine is warm, (Which is normal), but, is almost stalling out, clean your IAC.
Old Jun 12, 2008 | 06:18 PM
TxDox21's Avatar
I was thinking that it could be lower due to high temps and high humidity here. It does seem to run better at night.
I do not believe my engine has the IAC. I took off the throttle body last time and cleaned everything I could find that was dirty. I read the write up on how to clean the IAC, but did not see the parts pictured.
I just put some seafoam in the gas tank this evening and will be driving about 200 miles tomorrow so I will see what happens.
Thank for the help
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
1996Taco
Jul 20, 2015 12:02 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
