Interior led question...
Old Jun 4, 2008 | 10:19 PM
kmchby76's Avatar
I just installed LED lights in the interior. I put 1 in the dome light and 2 in the map lights. The problem is this, the driver side map light works no problem however the passenger side does not. To rule out a faulty bulb, I swapped the bulbs and all bulbs work. I just have no idea why the passenger side light does not work.
Old Jun 4, 2008 | 10:25 PM
corax's Avatar
polarity? LEDs only work if positive and negative voltage are on the correct terminals
Old Jun 4, 2008 | 10:51 PM
O.State4runner's Avatar
yup i had that same problem ... stupid polarity
Old Jun 4, 2008 | 11:10 PM
kmchby76's Avatar
So, can anything be done about this? Have you been able to resolve this or did you just not use the LEDs?
Old Jun 4, 2008 | 11:30 PM
corax's Avatar
I don't really know, but you might be able to pull the map light down and switch the polarity from the back side. Either swap wire location to the bulb socket or cut and solder
Old Jun 5, 2008 | 12:04 AM
kmchby76's Avatar
Why would the one side not work but the other? Aren't both sides wired the same.
Old Jun 5, 2008 | 01:22 AM
kmchby76's Avatar
Ok, I fixed it. I feel a bit dumb after this one. Somehow, I managed to put the bulb in on the passenger side backwards everytime. I happened to try something very simple. I reversed the bulb and wouldn't you know it, it worked. Yeah for me. Thanks for the input.
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
voiddweller
Sep 28, 2015 11:21 PM
Scotttekoch
Sep 28, 2015 10:30 PM
toyotasaurus
Sep 24, 2015 03:30 PM
