Chaotic Idle Then Death!
Old Jun 6, 2008 | 04:40 PM
BUZY's Avatar
I just got this problem recently where i'll come to a stop then the car starts to idle like its going to die then gives up and die. It happens at almost every stop. is this a MAF sensor problem? I do have a K&N intake and i've heard more bad things about them then good, or is it something else? it's driving me crazy!
Old Jun 6, 2008 | 05:25 PM
BigBallsMcFalls's Avatar
yes . .
Old Jun 7, 2008 | 06:29 AM
97ltd4x4's Avatar
I had that problem a while back.stopping and engine stumbles,idles down then dies.My Idle Air speed control valve was sticking/gummed up.I sprayed it out w/carb clean through the throttle body port,(its the round hole on the bottom of the throttle body once you get the intake boot off,infront of the butterfly)...You can also remove it and really clean it out(directly below and attached to the throttle body),I would get a new rubber gasket for the IASCV if you plan on doing that...Its been good for about 10k now.
Old Jun 7, 2008 | 08:14 AM
BUZY's Avatar
If I want to clean the throttle body do I have to remove it first? or is it possible to clean it w/out removing it?
Old Jun 7, 2008 | 08:37 AM
BajaRunner's Avatar
Sounds like its definetly your IAC
https://www.yotatech.com/forums/f123...ac-pics-92286/
Old Jun 7, 2008 | 10:01 AM
97ltd4x4's Avatar
You can just take the intake boot off,spray carb cleaner into the hole infront of the butterfly with the carb cleaner straw,spray a couple of times,might even want to hit w/compressed air inbetween the sprays(air in a can will work in a pintch).clean the throttle plate butterfly(hold open throttle plate,wipe clean....put back together...Should get you by untill you have to remove the IAC and really clean it.
Old Jun 7, 2008 | 11:18 AM
BUZY's Avatar
thanks for the info, looks like i have a weekend project.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
Sarcazmo
Aug 15, 2015 08:22 PM
ViperTT
Aug 14, 2015 05:27 AM
