rear diff fill bolt size?
Old Jul 3, 2008 | 11:11 AM
Spence1016's Avatar
hey my axle seals are leaking and i need to add some more oil soon before i get them replaced and dont have the wrench to get the fill bolt off, biggest ive tried are 3/4" and 19mm but both are way to small, and my crescent wrench just wont adjust to the right size. so which size should i pick up?
Also how difficult is replacing the seals? Im only 17 but consider myself very handy just inexperienced compared to all you vets, should i attempt it or take her to the dealership?
Thanks in advance,
Spencer
Old Jul 3, 2008 | 11:15 AM
nick_8787's Avatar
It's a 24mm or 23mm I believe. Two nights ago I spent all night in the shop taking out the third member to replace my seal. It was a lot more of a job then I thought it would be.
Old Jul 3, 2008 | 11:44 AM
toy89yota's Avatar
its 24mm
Old Jul 3, 2008 | 11:56 AM
HOOKED's Avatar
Here is one to look at it if you do it yourself you can buy a locker for what someone charge you.
Replacing the inner seals on the rear axle is a piece of cake.
-get new rear seals from the dealer
-drain the diff fluid
-disconnect the ebrake cable
-disconnect the brake lines
-unbolt the 4 bolts on the backing plate
-pull the whole drum assy/axle out
-pull the old seal out (I find it easier with a seal puller)
-install new seals (pound in easier if you keep the new seals in the freezer
overnight)
-put everything back together, fill up the diff and bleed the brakes
When you are putting the axles back in, be careful not to rest the axle shaft on the new seal or it could damage it, and you will be back in the same boat. If you have oil all over the rear drums, you may want to pull the drum off and clean the rear brakes.
http://www.jaroca.com/4RUNNER/Hooked_4runner.htm
87 4-Runner
Things ready to order or to install
488 Gears
Rock Sliders
Aussie Locker in the Back
Making my own 1 1/2 Ball Joint Spacer
Rear Shackles
Old Jul 3, 2008 | 12:17 PM
Spence1016's Avatar
thats a good point but i wont be locking up my 2wd =/ i guess i could spend it on 4wd tho =]
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
Yotoder865
Jul 9, 2015 07:51 PM
