Climate Control screen lights
Old Sep 19, 2007 | 10:37 PM
chad99's Avatar
Just wanted to post up that I changed my climate control LCD bulbs and the ones that were mentioned in the tech section weren't available at any of the dealers close to where i live, so i took the bulbs into the dealer and they were able to find ones that were pretty close to the ones needed just the part that has the molded in hooks were a bit thicker I just got a razor blade and cut it back a bit, really easy works fine.
The part number is 90010-09017 and i picked mine up from Dublin Toyota $5.52 each (yea i know expensive for a damm bulb but they always mark up the crap here in the bay area, at least it seems to me they do).
Old Sep 19, 2007 | 10:49 PM
DeathCougar's Avatar
better than buying a whole new assy for ~$800!!!
Old Sep 20, 2007 | 07:48 PM
DSN46's Avatar
I had to replace one bulb on the far right side of the climate control screen, but I thought that since I had it apart, I might as well change every bulb I came across on the way in and out...... Good Lord! Talk about a "bulb hunt".
I had to return to the dealer several times... they had to order the stupid things over and over (they even had my VIN) until after two weeks they finally got the numbers right. What a PIA.
At any rate, I'm glad your experience was reatively easy!
James
Old Sep 21, 2007 | 08:44 AM
chad99's Avatar
haha yea true if it was 800 id say screw it
Old Sep 21, 2007 | 08:46 AM
chad99's Avatar
James
yea it seems no one keeps them in stock....i was going to replace the button lights but it was so easy to take out ill just do it again when i need to, plus this way i can spend it on gas hah
Old Sep 21, 2007 | 11:02 AM
Tikal769's Avatar
that rocks, my lights are completely out. Got a tutorial to help me out with my limited?
Old Sep 21, 2007 | 02:47 PM
k_southman's Avatar
climate control
Don't mean to jack your thread...but I am still having a rough time with my climate control. The buttons just don't seem to do anything. I took it all apart and cleaned all the buttons with electrical conector cleaner, still no good. Mostly the "auto" "AC" and "mode" buttons. Any idea's or opinions would be great...I really don't want to shell out the $800 for a new one.
Old Sep 21, 2007 | 03:09 PM
1999runner's Avatar
mines the same way i have to push those buttons like 50 time to change the setting
Old Sep 26, 2007 | 05:21 PM
chad99's Avatar
I used this from the tech section
https://www.yotatech.com/forums/f127...acement-70183/
kman and 1999 sorry got no real ideas but i did wonder about that ribbon cable, might that have anything to do with it?
Old Sep 26, 2007 | 06:11 PM
sdstud212001's Avatar
I noticed your part # were different from write-up. How can I be sure I am getting the correct ones? I just need the LCD display lights.
Old Sep 26, 2007 | 07:30 PM
chad99's Avatar
yea my part number is the wrong part but i made it work....i would first try to find the ones mentioned in the tech section.
Old Sep 26, 2007 | 09:02 PM
Sweet thanks
Charecter1
Nov 6, 2023 10:08 AM
kirkrunner
Jul 27, 2015 07:59 PM
rushw
Jul 18, 2015 01:46 PM
daddio
Jul 18, 2015 10:20 AM
dropzone
Jul 16, 2015 02:00 PM
