MAF question
Old Sep 26, 2007 | 08:59 AM
highmilesrunner's Avatar
MAF question
in attempting to clean my MAF sensor over the weekend, i pulled up the link on 4x4 wire:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
ok, am i a total retard or am i missing something? my MAF sensor doesn't look like the pictures shown on the link at all. Mine seems to be encompassed inside of a black box that i think said Denso on it. i unplugged the sensor, but there weren't 2 screws to detach the MAF. did i miss something or is there another type of MAF that i may have? it's a 97 SR5 4x4and any suggestions would be great.
Old Sep 26, 2007 | 09:02 AM
frodin1's Avatar
Do you have any pics of yours?
Old Sep 26, 2007 | 09:03 AM
no, but i will surely take some tonight and post them back. of the other maf's i have seen (on ebay, or wherever) they look different from mine. like mine is all contained in a box or something...
Old Sep 26, 2007 | 09:13 AM
86tuning's Avatar
Originally Posted by highmilesrunner
it's a 97 SR5 4x4
4 or 6 cylinder? and.... why are you trying to clean it?
Old Sep 26, 2007 | 10:14 AM
Jdizzydub's Avatar
My rig is a 97' sr5..but it's kinda hard to tell without pics of what you're meaning. I took mine out nad cleaned it with the same stuff in the write up when I was tidying up the engine bay. I would say mine looked the same but I could see the two sensor wires in mine, so I just cleand down the cylinder or center of the MAF and left it at that. I do know that it needs to remain installed or a check engine light will fire. Good luck
Old Sep 26, 2007 | 10:39 AM
mt_goat's Avatar
There was a different style MAF on the earlier trucks, I seem to remember a change around 97, but don't quote me on that.
Old Sep 26, 2007 | 11:04 AM
it's the 3.4. well i know the previous owner never cleaned it and it has high miles, so i thought it may be a good idea. my CEL is also on but i'm sure its due to the front oxygen sensor.
Old Sep 26, 2007 | 11:13 AM
this is a picture of one like mine that i just found:
http://image6.autorevo.com/386/pics/...02dab87ec1.jpg
this is off ebay, but is identical to my fitting. any ideas?
Old Sep 26, 2007 | 11:39 AM
Greedy's Avatar
Looks like you have the older style MAF sensor. It is completley enclosed in and integrated with the tube. You need to take off the clamp holding the intake tube to the MAF (the metal clamp with a screw in it between the MAF and throttle body)and then disconnect the MAF tube from the air box.
Old Sep 26, 2007 | 11:46 AM
i thought about trying to disconnect that center piece (the one that contains the MAF) but i loosened that clamp and it still seemed reluctant to detach, so i didn't force anything. i then tried to pull out the part that connects to the air filter, but it felt like i was forcing it so i just thought i'd run it by you guys on yotatech to see if you had dealt with this type before. i'll get in there again and get it loose. thanks greedy
Old Sep 26, 2007 | 11:48 AM
any chance that spraying that electrical connection cleaner through the air filter box and forcing it into my goofy MAF casing would clean it? i'm thinking the motor would need to be running so it would pull that stuff through there but i'm not sure if it would damage anything by doing it that way?? just a thought.
Old Sep 26, 2007 | 12:12 PM
Greedy's Avatar
I wouldn't get it wet while it is running and the MAF of your style is very expensive so be careful.
Old Sep 28, 2007 | 04:26 PM
MTL_4runner's Avatar
You do that and you'll ruin it for sure......
Here's the cleaning process your looking for on a 96-98 MAF:
http://www.ultimateyota.com/index.ph...&topic=1033.15
smthwsn357
May 1, 2024 07:28 AM
mussy01
Dec 13, 2016 08:20 PM
Tacoma1313
Aug 17, 2015 05:44 PM
Koolbananass
Aug 12, 2015 01:59 AM
JefferDean
Jul 31, 2015 10:39 AM
