Old Mar 30, 2016, 03:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Steering & Suspension Guides
Print Wikipost
Just did steering rack bushings
Old Oct 8, 2007 | 08:26 PM
JEDI87's Avatar
Overall it was a simple job, took about an hour and a half from start to finish. I found that an old clutch alignment tool works awesome to pound the old bushings out, only took a few hits. The steering is quite a bit more responsive, probably because I had about a 1/4" of play in the old ones.
Old Oct 8, 2007 | 08:51 PM
Skrillah's Avatar
Did this help with an steering wheel shake, with bumps or just in general? I suppose its probably a worth while upgrade since its what like 20 bucks?!
Old Oct 8, 2007 | 10:17 PM
arjan's Avatar
Did mine a while back, the original ones weren't bad. I didn't notice a major difference, but it feels good to have it done anyway.
Vibrations will be more prominent, because the ply bushings are stiffer and absorb less. That's why you get tighter steering response.
Old Oct 9, 2007 | 08:17 AM
mkgarrison5's Avatar
what kind of bushing did you guys get?
Old Oct 9, 2007 | 02:42 PM
frodin1's Avatar
I got mine through http://www.wheelersoffroad.com/4runnerrackbushkit.htm as well as a swaybar kit.
Old Oct 9, 2007 | 03:28 PM
JEDI87's Avatar
I could feel my rack bouncing around over bumps and steering was sloppy. After I installed the bushings, the steering is crisp and no more slop over bumps.
I got mine from Summit racing. I'll get a part #
Old Oct 9, 2007 | 04:44 PM
arjan's Avatar
That's where I got them also. They supply a special metal sleeve for the 4Runners.
Old Oct 9, 2007 | 06:52 PM
Jerm's Avatar
Got mine from wheelersoffroad as well. The only thing I don't like is the vibration I feel now that I didn't before, but other than that it's a good investment.
Old Oct 9, 2007 | 06:58 PM
JEDI87's Avatar
I fell no vibration at all. Mine is the energy suspenion kit. I read that alot of people had to drill out the 3/4" sleeve but mine came with 2, I used the bigger one and the bolt fit perfect.
Old Oct 9, 2007 | 08:11 PM
urbanj's Avatar
Mine should be here by the end of this week. I know it will help huge considering I can see the rack moving around. It's very prominent. I'm wondering about the bump stops and sway bar bushings I got too though.
Old Oct 10, 2007 | 04:45 AM
MTL_4runner's Avatar
Unfortunately that's the tradeoff for having tight steering.
It does become a little less pronounced over time though.
Old Oct 10, 2007 | 07:26 AM
arjan's Avatar
You mean you get used to it
Old Oct 12, 2007 | 02:30 PM
urbanj's Avatar
They just came in today. Did you guys use the bumpstops?
I don't think I will even try them.
1uzRunner
63
Nov 10, 2018 03:58 PM
Papadeath
Sep 14, 2015 10:26 PM
Pocoyota
Sep 8, 2015 02:41 PM
128keaton
Sep 3, 2015 05:09 PM
dguzzi
Sep 3, 2015 08:48 AM
