E-Locker Identification
Old Sep 20, 2007 | 11:46 AM
timdawg's Avatar
I am actively looking for a 3rd generation 4Runner and saw a 2000 Sports Edition SR5 this morning.
On the Limited, there is a button that reads "RR lock" which is obvious.
However, on the SR5 that I saw this morning, by about the left knee level, left of the steering wheel there was a button that had the identification of a four wheel drive drive train, with the front axle, front tires turned to the right, there was an "X" marked by the center differential (transfer case), and the showing of the rear axle.
I asked the salesperson, he didn't know what the heck it was. I am guessing that is the E-diff locker.
Am I correct?
Thanks all!
Old Sep 20, 2007 | 12:01 PM
twitchee2's Avatar
Thats the center diff lock i believe.
Old Sep 20, 2007 | 12:04 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
It is the center diff lock, the Rear diff locks will have the RR Diff Lock button near the dimmer and also the rear axle 3rd member will have a small motor on the outside with some wires leading to the interior of your car
Old Sep 20, 2007 | 12:12 PM
black runner's Avatar
that button turns your IFS into a SAS.
Old Sep 20, 2007 | 12:29 PM
timdawg's Avatar
Thanks, in that case then the search is still on until I find one that has the RR dif option.
By the way, if I decide to change the R&P can I still use the E-diff or I have to switch to aftermarket lockers?
Furthermore, with a 3" lift and going with 33's using factory 16" wheels, do I have to use wheel spacers to eliminate body rub? Or should I just go with the inner fender trim approach?
Thanks all.
Old Sep 20, 2007 | 01:33 PM
dijlop's Avatar
dang ur needy. hehehe.
Old Sep 20, 2007 | 01:40 PM
One_96TR4's Avatar
If you decide to change gears the e-locker is still usable. With a 3inch lift 33's will clear no problem. Some ppl have had a little minor rubbing with the wheels stuffed on stock rims but others have had no problems whatsoever.
Old Sep 20, 2007 | 02:08 PM
jlohr's Avatar
what is ifs and sas... i have the button he is talkin about on my 4runner
Old Sep 20, 2007 | 04:20 PM
jjrgr21's Avatar
Independent front suspension
Solid Axle Swap
Old Sep 20, 2007 | 05:33 PM
jlohr's Avatar
so what exactly does the button do when pressed?
Old Sep 20, 2007 | 05:40 PM
4Runner202020's Avatar
ya its the center diff lock from my understanding they dont really do much. get the rear if possible.
Old Sep 20, 2007 | 06:43 PM
jjrgr21's Avatar
RR DIFF LOCK, locks the rear diff together, both wheels are turning at the same speed, but open diff will spin the tire with the least amount of resistance i.e. the one in the air, mud, snow. the rear locker is like having one solid piece connecting the two sides, instead of 2 separate pieces
Old Sep 20, 2007 | 10:18 PM
nc994run's Avatar
To clarify, if you have an open diff (no diff lock) the power goes to the path of least resistance e.x. if one tire is in the air, it will get all the power. When the Rear differential lock is engaged, both rear tires receive 50% of the power, regardless of the traction (you could have one tire off the ground and the other would still get 50% of the power)
Old Sep 21, 2007 | 05:59 AM
jlohr's Avatar
im still confused on what the button does (not the rear rr dif lock button)..the one described in the first post
Old Sep 21, 2007 | 06:15 AM
04 Rocko Taco's Avatar
It locks the center diff, which means the front and rear will both get 50% of the power... but the left and right sides are still open, so a tire in the air will still just spin on that axle...
Old Sep 21, 2007 | 10:13 AM
jlohr's Avatar
so if i dont use that will the tire in the air still spin?...it sounds like its just the same as putting the truck in 4wd.....
Old Sep 21, 2007 | 11:30 AM
d0ubledown's Avatar
no..in 4wd w/o center diff lock, you will have and open tcase..just as you would have open diffs. center diff lock locks the tcases (front wheel & rear wheel drive) together, so they each get equal power.
Old Sep 22, 2007 | 07:39 AM
jlohr's Avatar
so when not activated all the power goes to one rear wheel and when i push the button half goes to the front and half to the back?
Old Sep 22, 2007 | 09:07 AM
BajaRunner's Avatar
Yeah basically.
In 4wd, with open diffs, you actually are running basically in 2wd if you have two wheels in the air. A true 4wd has locked diffs, and all 4 wheels are turning at the same power/revolution/time.
Old Sep 22, 2007 | 10:09 AM
jlohr's Avatar
thats gay.. so my 4wd is actually 2wd cus only one in the front and one in the back get power... and that would mean that this button does the same thing as putting it in 4wd right?
