CV Axle problem
Old Sep 22, 2007 | 01:00 PM
dyetrix06's Avatar
CV Axle problem
Hey guys, just finished putting an aussie locker in the front of my runner(which I HIGHLY suggest, it is amazing!). Anyways, got it all back together with amsoil, only to hear a pop when i put it in 4wd after a while and I believe I was taking a turn. I look under, and only notice it seems like my cv has just popped out right behind the snap ring.....i think no big deal, ill pop it back on, so I do, and same thing happens. After wheeling, I check for leaks, and there are still no leaks or anything of that sort, so I thought I would just take the wheel and hub nut off and pop it back in, since pressure might be pulling it out.....I did all of this, and it still pops out in 4wd. Any ideas as to why? Maybe a bad snap ring? Thanks! Also, why wouldn't it be leaking, because I had NO leaks from a full day of wheeling(it's the cv on the drivers side of the diff.)
Old Sep 22, 2007 | 06:18 PM
Skrillah's Avatar
Hmmm...not sure...probably time to just replace the CV axle and get it over with.
Old Sep 22, 2007 | 08:04 PM
dyetrix06's Avatar
they are less than month old, I just replaced them.....did not have this problem the first time I put them in, then I installed the locker, and the drivers side one wants to pop out
Old Sep 29, 2007 | 04:48 AM
MTL_4runner's Avatar
Take it back and get a replacement because the c-clip on it is bad.
Before you do that you can also try expanding the c-clip and see if that makes it hold better.
Old Sep 29, 2007 | 05:47 AM
netwt12's Avatar
Did you get it from advance auto parts? i've had trouble with axles that were a little short from them before that did the same thing.
oldirtydirt
Feb 23, 2020 09:30 AM
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
