4Runner T-Case Breather Extension
Old Oct 6, 2007 | 05:38 PM
OSU4Runner's Avatar
Has anyone extended their T-case breather on a 3rd gen 4Runner? I know the T-case is already pretty high up, but I'd like to do it just incase. Can I use the same union fitting on the t-case as the rear diff breather? I did some searching, but couldn't find a good write up or anything very concise
Old Oct 15, 2007 | 12:42 PM
OSU4Runner's Avatar
bump...nobody has done this?
Old Oct 15, 2007 | 01:11 PM
4Crawler's Avatar
If it is a threaded breather, then unscrew it and see if it is a 10mm thread, if so the diff breather mods would work. Otherwise, see if the cap pulls off and try fitting a hose over it. If the above are no good, try this:
Since my '85 tranny and t-case(s) have no breathers, I drilled/tapped holes for pipe thread fittings:
http://www.4crawler.com/4x4/ForSale/...Shifter/3.html
My reason for doing this is not so much keeping water out, rather in keeping gear oil fumes out of the cab, since the early boxes are vented through the shifters, the hot oil fumes can get up into the cab.
Old Oct 15, 2007 | 01:16 PM
OSU4Runner's Avatar
Thanks for the help....I'll check it out
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 16, 2015 06:16 PM
andrewtexas123
Jul 14, 2015 04:29 AM
