How much for new engine 3.4?
Old Oct 7, 2007 | 05:25 PM
ADH8796's Avatar
Well I think my engine bit the big one last night. I was sitting at a stop light and pow (followed by all the oil in my engine leaking all over the road) took off my skid and sure enough I have a whole the size of 2 quarters in my oil pan. I don't know if it damaged the block or not being that the whole is in the oil pan but I'm sure it's not good. I figure worst case is I have to get a new motor from toyota so how much do you figure that will run $$$ ?
Old Oct 7, 2007 | 05:30 PM
Texas_Ace's Avatar
Sorry for your problem.
I have seen them for anywhere from $1500 for a used engine to $15,000 for a race built engine.
But for a desent one i would expect somewhere around $2500 - $5000
Old Oct 7, 2007 | 06:05 PM
OSU4Runner's Avatar
Yep $1500-$2000 for a good used 3.4
Old Oct 7, 2007 | 08:14 PM
LJ_24's Avatar
Rebuilt Toyota Engines
Old Oct 7, 2007 | 08:50 PM
paddlenbike's Avatar
A brand new shortblock from Toyota should be around $2600. If the heads are reuseable, I would go this route.
Old Oct 7, 2007 | 09:26 PM
fillsrunner4's Avatar
did the motor die or keep running right after the pow? take off the oil pan its 14 or so small 10mm bolts. check for metal shards, if it was a piece of crank or a bearing you would know pretty quick. if you take it off and find nothing like that still i would do a check by turning the motor over a few rotations via turning the crank bolt. take a flashlight and inspect. could be you just need a new oil pan saving tons of $$$$$$$
Old Oct 7, 2007 | 09:47 PM
thefallman's Avatar
https://www.yotatech.com/forums/f2/b...9-01-a-126261/
Old Oct 8, 2007 | 04:55 AM
Nate08's Avatar
I think I saw one at www.trdparts4u.com for $3500 new. Could be mistaken, but I'm pretty sure I saw it there.
Old Oct 8, 2007 | 06:10 AM
KZN185W's Avatar
what caused the holes in the oil pan?
Old Oct 8, 2007 | 06:39 AM
ADH8796's Avatar
I don't know looks like the bottom side of the rod?
Thanks for the responses guys keep them coming. I have Toyota looking at things right now.
Old Oct 8, 2007 | 06:44 AM
thefallman's Avatar
they coe up on craigs list ever now and then.
Old Oct 8, 2007 | 07:15 AM
Speedy's Avatar
How many miles were on your motor? Keep us posted on what Toyota finds.
Old Oct 8, 2007 | 08:23 AM
ADH8796's Avatar
That's what's crazy I only had 136,000 mi
I'll let you know when I hear from toyota
Old Oct 8, 2007 | 08:47 AM
aviator31's Avatar
Oh Anthony, say it ain't so. Man, REALLY sorry to hear that!
Old Oct 8, 2007 | 08:55 AM
ADH8796's Avatar
Yep sure enough.
Just talked to toyota they are thinking I'm going to need a new short block but they are going to get back to me on that.
Old Oct 8, 2007 | 09:00 AM
netwt12's Avatar
$2932.12 is dealer list on a 3.4L longblock
straight labor time is 20.9 which would come out between 12 and 16 hundred dollars depending on rates. i would be looking for a salvage engine if it were mine.
Old Oct 8, 2007 | 09:40 AM
MTL_4runner's Avatar
Um, no, $2900 is dealer list for a shortblock not a longblock.....big difference there.
The longblock will run you ALOT more than that.
The best option by far at this point is a lower mileage used motor......JDM import if you can find one. The other thing you can do is to have a good machine shop rebuild the short block and then get a rebuilt set of heads from these guys http://www.cylinder-heads.com/ (they are $300 per side and they're a very professional outfit). The rest of the stuff you can either go to the dealer like Northridge or Toyota of Dallas or I've also had very good luck from these guys http://partsdinosaur.com/ (ask for Bruce, VERY helpful guy and they sell ITM parts which are what alot of the professional engine builders use) for parts on the 5VZ-FE motor. If you decide to rebuild your own cylinder heads, make absoultely sure you have them resurfaced (that step is CRITICAL to getting a good HG seal).
You can see my ordeal rebuilding mine over here:
http://www.ultimateyota.com/index.ph...6&topic=2241.0
Old Oct 11, 2007 | 05:47 PM
soarerjzz30's Avatar
At those prices, you should go for a 1kzte swap.
Old Oct 11, 2007 | 06:44 PM
ADH8796's Avatar
Found a used engine in good shape only 70,000 miles will arive tomorrow I will be replacing water pump, timing belt, rear main seal, main drive belt, and a few other things. Got a killer deal on everything including labor total is going to be $3100 after it's all said and done. Might have it back as early as tomorrow or Saturday.
Old Oct 11, 2007 | 06:50 PM
MARSHALLMAY's Avatar
that's pretty cheap considering that's how much you'd pay to buy a supercharger and have it installed.
