Where to buy MAF?
Old Sep 29, 2007 | 03:29 AM
Nismo Convert's Avatar
Where to buy MAF?
So I called Toyota Canada today and they wanted $1100 for MAF, Toyota in they wanted 650, any where to get it cheaper?
thanks.
Old Sep 29, 2007 | 04:01 AM
mt_goat's Avatar
thanks.
I got one on ebay for about $30.
Old Sep 29, 2007 | 04:39 AM
MTL_4runner's Avatar
Ebay is a good place for them for sure.
If you have a 5VZ-FE (3.4L) motor, then you need a MAF.
There's a few different models that use the same MAF (not just 4runner/tacomas):
http://www.ultimateyota.com/index.ph...11253#msg11253
If you have a 3VZ-FE (3.0L) motor, you need an AFM not a MAF and those are more expensive.
Once again there were several vehicles that used the same part.
Old Sep 29, 2007 | 06:02 AM
mt_goat's Avatar
Here's one for a 2000-2003 5VZFE:
http://cgi.ebay.com/ebaymotors/2000-...QQcmdZViewItem
Old Sep 29, 2007 | 11:07 AM
TOY89's Avatar
Yep you cant beat Ebay....
Old Sep 29, 2007 | 01:54 PM
I tried eBay for the MAF, it is for the 2.7 3RZ but it's for the 97, where I have a 95, and the numbers on top don't match. Not sure if it matters, but I didn't buy it because I didn't want to risk it.
Thanks.
Old Sep 29, 2007 | 07:45 PM
CTRJ's Avatar
Thanks.
Often the parts that come out of your Toyota will be different. Part numbers change and are often updated. Don't let that scare you.
Old Sep 29, 2007 | 11:21 PM
Well I have learned enough from my Rx7's to know they can change enough from year to year, maybe Toyota is different. So you're saying a 98+ MAF should work? Would a V6 MAF work on the 4cyl?
Thanks
Old Sep 30, 2007 | 01:53 AM
Well in a last ditch effort to not have to buy one, I sprayed the MAF with a different kind of contact cleaner, and it worked pretty well, the scanner has a green light instead of a yellow one like before, so it appears that I have fixed it.
Old Sep 30, 2007 | 05:55 AM
You probably didn't use the right stuff to clean it.......contact cleaner doesn't work very well at all IMHO.
Good thread about that here:
http://www.ultimateyota.com/index.ph...6&topic=1033.0
Old Sep 30, 2007 | 09:01 AM
Before I used brake clean, I have used it on other cars with great results, not on my truck tho, I went to Crappy Tire, bought the 5.99 contact cleaner, and it worked perfect, I have already noticed an improvment in mileage.
jb451
7
Oct 7, 2022 06:58 AM
pickle6415
Oct 19, 2015 08:08 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
icentropy
Sep 10, 2015 05:03 AM
LJR
Sep 5, 2015 06:02 AM
