12v Outlet on '98 is dead
Old Feb 21, 2008 | 10:05 AM
UNR.Grad's Avatar
My brother has a '98 4Runner and I guess on a recent road trip he was using an inverter to power a DVD player or something, but the outlet went dead. He checked the fuse and it's good. I haven't checked out the car, but he fixed my computer so I have to fix his outlet. He's dropping the car off this weekend, any ideas? Do you think the relay could have gone bad?
Old Feb 21, 2008 | 10:42 AM
ozziesironmanoffroad's Avatar
put a autozone 12V in there lol
Old Feb 21, 2008 | 12:33 PM
UNR.Grad's Avatar
What I might do is just rewire his stock outlet and have it coming directly from the battery with an inline fuse and ground the negative. Any reasons not to do that for a simple fix?
Old Feb 21, 2008 | 12:37 PM
Adam F's Avatar
Cig lighter has a fusible link. It's probably blown. Happened on a 96 I use to own. I just soldered it back together. Been working fine for 5 years now.
Old Feb 21, 2008 | 12:53 PM
UNR.Grad's Avatar
Where would that be?
Thanks for the help
Old Feb 21, 2008 | 01:00 PM
bwhyit's Avatar
There is no fusible link for your power outlet. You have a 15 amp PWR outlet fuse. If you lost a main fuse or fusibale link you would have lost more than just your power outlet. Check the fuse with a volt meter on each side. If it's ok then check the outlet to see what you've lost (pwr or gnd). It's only 2 wires so it should be fairly easy for you to diagnose.
Old Feb 21, 2008 | 09:30 PM
UNR.Grad's Avatar
Thanks for the help
Old Feb 22, 2008 | 03:38 AM
Adam F's Avatar
You sure about that buddy?
Take the cigarette lighter assembly out of the dash. Look at the back of the unit. You will see a little brown "wire" hooked to it. That's your fusible link. It's probably burnt up and not making a connection. This was the problem with my 96 4Runner. I simply removed the link, and soldered a new piece of wire on.
Old Feb 22, 2008 | 03:45 AM
wjwerdna's Avatar
if you can't figure it out, search for a few other threads, I swear I have seen this problem come up more than once in the last month. It was the same thing, fusible link (not a fuse) on the back of the socket, replace or repair. After of course you check fuses, pretty sure cig lighter and aux sockets (if you have them) are on separate circuits...
Old Feb 22, 2008 | 04:20 AM
bwhyit's Avatar
Well unless the Toyota wiring diagram is wrong..... Then yes I am sure that a 98 4runner does not have a fusible link for the pwr outlet.
Old Feb 22, 2008 | 04:37 AM
bwhyit's Avatar
There is one detail thats not clear. Are you talking about the pwr outlet in the dash (cig lighter) of the power outlet by the rear door. Important to know.
Old Feb 22, 2008 | 04:41 AM
wjwerdna's Avatar
So you've taken it apart? A fusible link in this case is not a plastic replaceable fuse as you probably think, it is just a small wire meant to fail if needed (or at random). It is meant to be replaced as a whole unit (the socket). As explained in another thread covering this same topic, it is a slow-blow link designed to protect your vehicle from cig lighter being left in, since it wouldn't (most likely) blow the main fuse. It's not going to show it on a wiring diagram
Search Google for "cigarette lighter fusible link" and see how much this topic is covered in so many forums
Old Feb 22, 2008 | 10:35 AM
UNR.Grad's Avatar
Cig lighter. Thanks for all the help thus far guys, I'll let you know what I find!
Old Feb 22, 2008 | 11:27 AM
07sbock's Avatar
Just replace the outlet. It probably burned up?
If the fuse is good then the outlet is bad.
Chicken12
Oct 14, 2015 03:54 PM
Obmi
Oct 4, 2015 11:30 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
89YodaRunner
Sep 30, 2015 02:18 PM
voiddweller
Sep 28, 2015 11:21 PM
