2 Problems my 2000 has
Old Feb 20, 2008 | 08:22 PM
2000Runner's Avatar
1) difficult to shift to reverse occasionally
2) rpm goes up and down when idle
Any ideas?
Old Feb 20, 2008 | 08:38 PM
NwRunner's Avatar
ive had the exact same problem in my 1996 4banger. As for answers.. i would like to know as well.
Old Feb 20, 2008 | 09:19 PM
Caffeine's Avatar
Shifting into reverse being a bit tricky is pretty normal for manual transmissions.
Your RPM surge could be a lot of things. It may be related to your MAF sensor -- take it out and clean it with some connection cleaner as a cheap thing to try.
Old Feb 20, 2008 | 09:20 PM
Dare44's Avatar
could be a vacuum leak?
Old Feb 21, 2008 | 05:55 AM
edzo's Avatar
not enough info. could be anything.
reverse, I don't know. check the level of juice in the tranny
idle speed ? could be normal as the a/c clutch engage and disengage
or any of 7 other ecu related items. check MAF, check a/f sensors
Old Feb 22, 2008 | 08:25 PM
2000Runner's Avatar
Thanks guys, went to the dealership today for service. idle problem was from dirty air flow meter. they cleaned it and so far so good.
In terms of engaging reverse, I agree that it's a bit of tricky for reverse...
Old Feb 22, 2008 | 08:31 PM
toytech76's Avatar
I think all manual trans trucks have the reverse thing. I would usually shift into first then into reverse. Or I let the clutch pedal out a touch while trying to go into reverse. never had any problems
Ian Rogers's Avatar
i find when its hard to get in to reverse, i put it in 1st then go in to reverse. Reverse is the only un-sync gear in the trany, when it dose not line up there are no brass teeth like on all the other gears to help it line up. You can line them up by holding back on the gear shift and slowly letting off the clutch, this causes the input shaft to spin and alien the gears.
Old Feb 22, 2008 | 08:32 PM
Ian Rogers's Avatar
damm.. toytech76 types faster than i do
Old Feb 22, 2008 | 08:33 PM
toytech76's Avatar
lol. At least we think alike
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
