ABS and Full Floating Axles Set Up
Looking to Go to the Front Range Off Road Full Floating Axles kit but still retain my ABS--has anybody done this swap?
My idea as of current is to press off the ABS cog on a set of 3rd gen axles i have and measure ID. Buy FROR Axles and Measure OD and location of any angles...blah blah..machine cog as needed if it can be done.
Searches were pretty futile--is there anybody out there that has done it? Do you know somebody that has done it?
That idea sounds like it could work. I'd call FROR, they can probably get you the measurements you need, and help you figure out if your idea will work with their gear.
Called them and asked if anybody else had done it, didnt ask them what the measurements were. Wish they would just develop a solution. guess I will give them a call and see what they say about the measurements.
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: set of 4 ball joints. any torsion bar ifs 4wd
akaphilly
07-09-2015 02:27 PM
