got her running great now a code 25
Old Mar 26, 2005 | 02:27 AM
Boosted Chemist's Avatar
After all that idling like ลลลล i replaced the intake manifold gasket adn fixed teh crack in the manifold. I also had codes for air temp sensor and AFM so i was able to swap my filter box with a 93 yota 2wd (has a rod knock so it my new parts truck ) the part numbers matched up and its been running and idling great since i did so. But now every once in a while i get a code 25 (which i didnt get before) so im wondering should i maybe turn up the idle mixture a bit? I only have a set of headers on my truck so idk if its performance or the 2wd ran a little leaner.
Any input would be great
ps i have a 94 hilux 22re
Old Mar 26, 2005 | 04:38 AM
dogdenii's Avatar
CHECK your grounds. If it's intermittent, this is probably the case.
Old Mar 27, 2005 | 06:35 AM
engine grounds are good, i havent touched any of them, the CEL only hits when im cruizing in low rpms aroudn 45 mph. I just checked the o2 and it has some burns on the heat reflecting tape so maybe the sensor is truely bad, just wierd fix one problem and another emerges
crashburnoveride
Aug 28, 2015 09:20 PM
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
