transmission sound
Old Mar 28, 2005 | 06:08 AM
lee's Avatar
lee
transmission sound
hey guys, question for ya:
i know my truck. i know its sounds, i know what it should and shouldnt sound like.
lately ive been picking up on a strange sound during any kind of acceleration which i fear is a bad sign for my transmission.
its faint, but it sounds like the old looney toons cartoons when a plane was going down on its way to crashing. know what i mean?
it also sounds a bit like when certain cars are in reverse at higher speeds than a crawl, they make that whirrrrrrrr noise.
is that ok? am i worried for no reason? is this a noise thats always been there, im just noticing it more now?
thanks.
Old Mar 28, 2005 | 09:06 AM
lee's Avatar
lee
bump?
anyone!
Old Mar 28, 2005 | 09:36 AM
hillbilly's Avatar
Could be your T-case too. Just a thought, but you might want to give this a shot in a safe area:
Set your E-brake. Put your tranny in Neutral or Park. Shift the T-case lever to Neutral. Put your tranny in 'D', and give it a little throttle. If you don't hear the sound, the T-case MIGHT be the culpret. I emphasize 'might' because this is not a definitive test, but it might give you a better indication of where the noise is coming from.
Old Mar 28, 2005 | 09:47 AM
lee's Avatar
lee
thanks man, ill try that. the tranny shifts perfectly and im noticing no changes in the way it drives.. it just now makes that weird whirrrr...
Old Mar 28, 2005 | 09:55 AM
Mickdady's Avatar
While running this test make sure you do not put the vehicle back into park while the engine is running!!! Turn the engine off then put the vehicle in park. Because the trans is not hooked up to the rest of the drivetrain there will be nothing to slow the transmission down once you have let off on the throttle, you must turn it off to shift out of drive or you will hear the park lock pawl attempt to put the trans in park while in motion and it is not a pretty sound.
Old Mar 28, 2005 | 10:01 AM
lee's Avatar
lee
ill leave it running, shift the tranny in N then the 4wd shifter in N. then when im done ill move the 4wd shifter back to 4H, then the tranny to D.
thats what i always do when shifting things around.
Old Mar 28, 2005 | 12:41 PM
kyle_22r's Avatar
bearings in the tranny will make a howling noise when they go out.
i know 5th in a lot of older toy trannies was always a little noisy no matter what, but if it becomes really loud you have a problem. if it howls in 4th gear it's the input bearing(4th just locks the input and output shafts), if it howls in the other gears it's probably one of the countershaft bearings. either way, you'd be looking at a tranny rebuild.
Old Mar 28, 2005 | 03:15 PM
lee's Avatar
lee
its consistent throughout... its like a winding noise that is only really audible when accelerting at a consistent pace.. then it quiets when shifting, and starts again.
but really today made me think its nothing cause its so quiet and the tranny is functioning perfectly.. ill keep my ear on it. thanks!
Old Mar 29, 2005 | 05:55 AM
joatmon's Avatar
I had a similar problem. Does it make the sound with it in neutral and the clutch out? It whines in all gears but 4th?
My problem was the knuckle head who owned it before me ran the tranny low on oil so the input shaft and main shaft were toast and the cluster gear was done. The tranny shop said that it would cost more in parts to rebuild than to buy a reman tranny. Runs great now with a new tranny.
Old Mar 29, 2005 | 06:24 AM
lee's Avatar
lee
hmm.. thanks for the input. ill check it out and get back to you.
i had all fluids changed at my 60K inspection.
chuckross1957
Jun 28, 2019 10:19 PM
crammit442
7
Nov 29, 2017 12:30 PM
skoob
Oct 15, 2015 03:23 PM
Tigbucket
Jul 30, 2015 07:29 PM
jjrbus
Jul 17, 2015 07:06 AM
