Crankshaft Pulley Holder for 3.4L
I thought you guys said this tool was about $50.00. I'm finding it for $220.00
PN 9213-54015
see link:
http://www.etoolcart.com/index.asp?P...OD&ProdID=2027
Help me!
PN 9213-54015
see link:
Help me!
PN 9213-54015
see link:
Help me!
PN 9213-54015
see link:
Help me!
Just be sure to pretect the pulley from damage (I use a piece of an old bike tire to wrap around).
PN 9213-54015
see link:
Help me!
PN 9213-54015
see link:
Help me!
Be very careful, and just TAP the starter. You may have to tap more than once. If the thought of this makes you nervous then don't do it... go get a chain or belt.
Do not use this technique to tighten...
Originally Posted by valkyrie610
Old mechanics trick to break it free: using a socket & breaker bar, wedge the breaker bar against the top of the driver's frame rail and *quickly* bump the starter. Engine torque will break it free.
I’m more concerned about torquing the pulley during reassembley. If I can get the part for $50, it would be worth it in the long run. But for $220, I would rather manage without it.
Yeah, it is 19mm... I just did mine a couple of weeks ago... Good luck getting that bolt off it took some muscle! I would spray it with some kind of penetrating oil and let it sit overnight just to give you that much more of an advanatage.
Here is a pulley holder I found on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll...880776999&rd=1
Here is one from toolking: http://www.toolking.com/shop/view.asp?ID=12839
I personally made my own that rested on the frame so that I didn't have to have someone else hold it while I broke the bolt free.
Good Luck
Good Luck
LCE_Performance
Oct 1, 2015 01:03 PM
charlie_fong
Sep 27, 2015 10:06 PM
