Crankshaft Pulley Holder for 3.4L
Old Mar 24, 2005 | 06:05 AM
DOT3's Avatar
I thought you guys said this tool was about $50.00. I'm finding it for $220.00
PN 9213-54015
see link:
http://www.etoolcart.com/index.asp?P...OD&ProdID=2027
Help me!
Old Mar 24, 2005 | 06:17 AM
MTL_4runner's Avatar
PN 9213-54015
see link:
Help me!
Why not just rent a strap or chain wrench and hold it that way?
Just be sure to pretect the pulley from damage (I use a piece of an old bike tire to wrap around).
Old Mar 24, 2005 | 06:23 AM
valkyrie610's Avatar
PN 9213-54015
see link:
Help me!
Old mechanics trick to break it free: using a socket & breaker bar, wedge the breaker bar against the top of the driver's frame rail and *quickly* bump the starter. Engine torque will break it free.
Be very careful, and just TAP the starter. You may have to tap more than once. If the thought of this makes you nervous then don't do it... go get a chain or belt.
Do not use this technique to tighten...
Old Mar 24, 2005 | 06:25 AM
This method also does work but it does make some nervous.
Old Mar 24, 2005 | 06:53 AM
DOT3's Avatar
I’m more concerned about torquing the pulley during reassembley. If I can get the part for $50, it would be worth it in the long run. But for $220, I would rather manage without it.
Old Mar 24, 2005 | 09:01 AM
DOT3's Avatar
Found it by calling OTC direct. $51
Thanks
Old Mar 24, 2005 | 06:06 PM
Gadget's Avatar
You have to also get the bar that clips to the part that bolts to the pulley.
Gadget
Old Mar 25, 2005 | 07:40 AM
DOT3's Avatar
Gadget;
I ordered the companion flange tool and the pulley holder.
Also I have the tensioner compressor and a torque wrench. I think that's all I need.
Thanks
Old Mar 25, 2005 | 10:13 AM
ACPlayer's Avatar
Do you guys know what size the bolt is that holds the pulley on? I am about to do the timing belt this weekend.
Old Mar 25, 2005 | 11:13 AM
drabnor's Avatar
19mm on mine
Old Mar 25, 2005 | 12:37 PM
ACPlayer's Avatar
The Toyota dealer parts guy told me the same. Thanks.
Old Mar 25, 2005 | 01:14 PM
braverex's Avatar
Yeah, it is 19mm... I just did mine a couple of weeks ago... Good luck getting that bolt off it took some muscle! I would spray it with some kind of penetrating oil and let it sit overnight just to give you that much more of an advanatage.
Here is a pulley holder I found on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll...880776999&rd=1
Here is one from toolking: http://www.toolking.com/shop/view.asp?ID=12839
I personally made my own that rested on the frame so that I didn't have to have someone else hold it while I broke the bolt free.
Good Luck
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
LCE_Performance
Oct 1, 2015 01:03 PM
EVars
Sep 29, 2015 02:06 PM
charlie_fong
Sep 27, 2015 10:06 PM
